Hi all
Iβm new to this so forgive the ignorant questions. π
I recently installed an Innovv Power Hub 2 on my bike. I wired it up as instructed, (battery side) red to negative, black to positive on the battery and yellow to a switched power source. I power the bike on and the Power Hub 2 lights up, switch the ignition off and after a while the power hub powers down. (All good) I also wired the other black wire from the Power Hub 2 (Device connection side) to the bikes frame as instructed. (Earth/Ground)
Now, how do I connect the K2 to the Power Hub 2?
I assume the red wire from K2 goes to one of the fused Power Hubs 2 red leads.
What do I do with the black and yellow wire from the K2?
1. Do I tap into the black wire from the Power Hub 2 which is connected to the bikes frame?
2. What do I do with the yellow wire from the K2? (The Power Hub is already tapped into a switched power source)
If I didnβt have the Power Hub 2, life would be easier, as I would just wire it up as I did the Power Hub 2, directly to the battery.
Any help is greatly appreciated. π
Thanks Shane
Please take a look here
https://www.innovv.com/forum/innovv-k2/k2-trigger-wire-and-power-hub
Hi Frostie and thanks for replying. I read that thread and Iβm confused as to why I would need a Power Hub if I am being instructed to connect the K2 directly to the battery.
You don't need the power hub to connect the K2.
The power hub is for connecting additional accessories. It is a separate product, which has nothing to do with the K2.
Thanks, I understand that, I will be adding more accessories in the future. I thought adding it now and connecting the K2 to it would save me from having to remove everything and rewire the K2 once I installed the Power Hub 2. So it seems best option is to remove the Power Hub 2 and install the K2 directly to the battery.
