The app doesn´t connect to DVR.
-WiFi shows that its on(both phone and DVR)
-Cameras and GPS are attached to DVR
-I have latest firmware
-App has been removed and installed again
-DVR has been reset
-WiFi connection has been removed and created again.
Last summer some point I stopped using it because it couldn´t connect to
the cameras every now and then (normally went away by turning the bike off
and on again)
Now I have installed it to one of my other bikes and can´t get it to work at all.
Am I missing something here or could there really be something broken inside the DVR?
What brand/model phone are you trying to connect to?
In the forum you often encounter problems with iPhones. I don't have an iPhone myself, but I often see that something needs to be done with airplane mode.
So if you work with an iPhone, this may be the cause of your problem. But @Jade _Innovv can undoubtedly tell more about this.
The video file was so huge I couldn´t upload it so here´s the link to my shared album with the video about the lights.
https://photos.app.goo.gl/FwhoUyD3Gj5SNPjf8
Still the same...
What about disconnect both two cameras, and only connect the REAR camera to the Front port? Please try this step and see if the K2 back to life or not?
Please do not worry, we will offer a good after service for you.
It behaves exactly the same with the usb charger.
WiFi light works as intended flashes and when connection is made stays solid
Camera light stays on so it is in standby
Hi, Panu , sorry for the problem, could you please disconnect the power converter and power the K2 with a power bank or usb charger, to see if the K2 starts to record or not? If still no Wifi, no record, please let us know the light indicators situation in the K2.
Thanks.
