After the latest... not sure if it was an app or firmware update since they both happened near each other... transferring files to the phone is much slower. Several minutes to transfer ~300MB.
That depends on the connection and the communication between Phone and Camera. that is same as the phone connect the home wifi spot, sometime it does not get fast as the usual.
If feel it was slow, disconnect the WiFi connection and reconnect it again.
It's been consistent over the last few transfers. Previously, it would transfer a gigabyte or two in a few minutes. This was while the progress bar was broken (only displayed 50% when the transfer was complete). Now the progress bar is accurate but the transfer is much slower - only a few hundred megabytes over the same time span.
I have the same experience using an iPhone 6s. Surely there has to be a better and fasPeter way to download files. I have to leave my accessory switch on to power the dvr and as slow as it it, it drains my battery. Short of removing the sd card and downloading it directly to a computer isn’t there a better “option” for a bulk down load. This needs to be improved.
Card reader, only when you have an easy access to the DVR. I'm more then disjointed about the interface also the app. Have you ever tried to download more the 3 Files :-((( it takes 30 Minutes than you can start the next batch. I hope they will come with some improvements.
I agree-- a download cable would have been nice and then at least i would not have to pull the seat off every time I want to download. I could just have access to the cable and plug into the laptop and download. Although I do not anticipate needing to download a bunch of files, it is difficulty to sort through all of them to find the one you want only using the WiFi setting and the app.
Or you can restart your phone.
Just checked and tested no difference comparing with before.
There is the limition for data transfer from WiFi.
This is WiFi data transfer speed in theory, in fact, there are many impacts to slow down the speed.
Get a card reader. Best way to transfer files to PC.
