K2 system. Firmware the latest.
Has been on bike for a few years now with no real problems apart from the odd corrupted video. Was working fine yesterday (well sort of but that is another story) went to check something today and noticed this happening with the lights. I cant access wifi or anything via the app.
I have since resetand also reloaded the firmware which did its normal red flashing.
The other day the rear camera wasnt recording all the time and a lot of video was corrupted. When you played on dashcam viewer a still was shown and a speed with engoine sounds.
https://youtube.com/shorts/IRMgwhKVJjQ?feature=share
Does anyone have any ideas?
Frostie Thank you for your time and effort. It is greatly appreciated. I will endeavor to try and find another front camera.
Hi Thanks for the time and effort you have put into helping me.It is greatly appreciated.
This is set up with rear camera in front socket and vice versa. No picture on the front camera only rear.
======== LogFile Begin =========
[2022/07/18 15:25:27]
F/W NT96663 Start ...
NAND support table version[2014_03_10-01]
usb_PowerOnInit: enter
usb_PowerOnInit: exit
CPU/CPU2/DSP clk = 420/420/270 Mhz ...PASS
DMA clk = 587 Mhz ...PASS
Memory = 262144 KB, Code/Resv/Stack/Heap = 8847/8/571/252717 KB
Binary = 5326 KB, Part = 1026/715/0/0/0/0/0/0/0/3585 KB
PwrLost = 0, PwrSrc = 2
NOVATEK SDK
Copyright (c) 2014 Novatek Microelectronic Corp.
Hello, World!
CHK: 193, NvtMain[0m
> CHK: 138, IO_InitGPIO[0m
pad_getDrivingSink gMclk:8__111
pad_getDrivingSink gMclk:128__222
pad_getDrivingSink gMclk:8__333
pad_getDrivingSink gMclk:8__444
System Boot begin
LD VERISON: LD_NVT
FW --- Daily Build: Jun 23 2020, 16:43:14
Power On Sequence = Safe
ERR:ramdsk_setParam() No Implement! uiEvt 2
ERR:ramdsk_setParam() No Implement! uiEvt 1
cpu2 power on ready
[ECOS]
uart main return 0.
ERR:PartLoad_Load() not init.
ERR:xFwSrv_Err() -22
[2022/07/18 15:25:28]ERR:System_OnStrg_DownloadFW() Process failed!
USB 1.5A
CONNECT to CHARGER
DxUSB_UpdateConnectType = 2
USB 1.5A
CONNECT to CHARGER
USB 1.5A
CONNECT to CHARGER
usb insert don't detect low battery
===================================== video fixed [Display_LCD]
WRN:pll_setClockFreq() Target(4) freq can not be divided with no remainder! Result is 48000000Hz.
DrvSound_SetAudioFeature
ERR:System_OnStrgInit_PS() PStore uiBufSize=262144
PS_DESC_BLOCK=1[0m
CHK: 6928, FlowMovie_FileDBCreate_Fast[0m
CHK: 6954, FlowMovie_FileDBCreate_Fast[0m
USB 1.5A
CONNECT to CHARGER
System Boot end
On Boot begin
SysExeMenuSettingFuncs SysGetFlag(FL_MOVIE_SIZE) = 5
----------->SENSOR_ID_2: 0 bResetStatus:0
ERR:AlgGetUIInfo() Error IPL Id = 0xffffffff
ERR:IPL_AlgSetUIInfo() Id: -1, SelIdx = 1126236193 error
===================================== sensor display [MASK=00000001]->[MASK=00000003]
WRN:System_OnSensorDisplay() dual sensor, but ImagePipe is not enabled, ignore!
===================================== sensor display [MASK=00000003]->[MASK=00000003]
===Movie Rec Set Vol = 100
MovieExe_OnGPS
MovieExe_OnParkingMonitor:0
UART2: Open success
Start GPS receive task
Mode {MOVIE} Open begin
-display count=1, mask=01, attach=01
sensor map = {00000000,00000001,ffffffff,ffffffff}
enable mask=00000001
Init_IMX322LQJ_THCV236(): IMX322LQJ_THCV236_init...
-sensor count=1, mask=0001, attach=0001, disp=0001
-lens count=0
uiMovieSize = 5
set uiMovieSize MOVIE_SIZE_FRONT_1920x1080P30
CHK: 289, Save_MenuInfo[0m
param set IPL change mode delay time = 100
ERR:gyro_open() uiRecv1 = 0xffff
GYRO OPEN Fail
WRN:MovieExe_OnMovieSize() should change mode
[2022/07/18 15:25:29]GYRO OPEN Fail
WRN:ImageApp_CamMovie_Config() Change IPL buffer count!!! 7
WRN:ImageApp_NetMovie_Config() Change IPL buffer count!!! 7
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
MovieFile: Photo folder PHOTO
CHK: 759, Movie_SetRecParam[0m
CHK: 806, Movie_SetRecParam[0m
ERR:Note_Ae_Init() AE Table 1 is not support.
ERR:Note_Ae_Init() AE Table 5 is not support.
ERR:ChgMode_IMX322LQJ_THCV236() ChgMode_IMX322LQJ_THCV236 to 1...
WRN:pll_setClockFreq() Target(0) freq can not be divided with no remainder! Result is 36000000Hz.
WRN:pll_setClockFreq() Target(2) freq can not be divided with no remainder! Result is 120000000Hz.
ERR:GSensor_I2C_Transmit() i2c ret = 2!!
ERR:GSensor_I2C_ReadReg() Error transmit data1!!
------GSENSOR_DA380 chip id = 0x13-----
-->DA380 get data:0
GSensor_DA380_open: 1 0..
fileid:0
GYRO OPEN Fail
[2022/07/18 15:25:30]WRN:MovieExe_OnMovieSize() should change mode
MovieExe_OnADASVoice:1
ERR:fs_remove() A:\K2.bin is not exist
---UIFlowwndDeleteFWFile..NG
Mode {MOVIE} Open end
On Boot end
USB 1.5A
CONNECT to CHARGER
WRN:System_OnSensorDisplay() dual sensor, but only connect single now, ignore!
[2022/07/18 15:25:31]USBConnectType=2
g_bKeyScanDelayoffEn = 0
CHK: 2144, UIFlowWndMovie_OnTimer[0m
IPL_PATH_1: 1 IPL_PATH_2: 0
liveViewError :0 0
[2022/07/18 15:25:32]
liveViewError :0 0
[2022/07/18 15:25:33]
liveViewError :0 0
[2022/07/18 15:25:34]
liveViewError :0 0
[2022/07/18 15:25:35]
liveViewError :0 0
[2022/07/18 15:25:36]
liveViewError :0 0
[2022/07/18 15:25:37]
liveViewError :0 0
close liveview timer id
UIFlowWndMovie_OnKeyWifiSwitch
AP start
[ECOS]system call
command=wifiipc -open 18870368 18881448 16061709 &
[ECOS]system call
command=dhcpipc -open 18884704 5504 20160719 &
gParamSndAddr=0xA1202060[0m
gParamRcvAddr=0xA1202460[0m
[ECOS]system call
command=usockipc -open 18882656 18883680 20160811 &
Network mod:0
UINet_WifiInit(): set wifi 0 1
[ECOS]sdio lookup 3
[ECOS]SDIO1 open: switch to 48MHz
sdio lookup 4
funcs = 0x1
tpl_ptr = 0x0
tpl_ptr = 0x1000
tpl_ptr = 0x1000
tpl_code = 0x20
tpl_link = 0x04
tpl_data =
0x4c 0x02 0x79 0x81
i = 4, ARRAY_SIZE = 4
tpl_code = 0x21
tpl_link = 0x02
tpl_data =
[ECOS]
0x0c 0x00
i = 2, ARRAY_SIZE = 4
tpl_code = 0x22
tpl_link = 0x04
tpl_data =
0x00 0x08 0x00 0x32
tpl_code = 0xff
tpl_ptr = 0x0
tpl_ptr = 0x1100
tpl_ptr = 0x1100
tpl_code = 0x21
tpl_link = 0x02
tpl_data =
0[ECOS]x0c 0x00
tpl_code = 0x22
tpl_link = 0x2a
tpl_data =
0x01 0x01 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x02 0x00 0xff
0xff 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00[ECOS] 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0xeb 0x00 0x6e 0x01 0x00 0x00
0x00 0x00
i = 42, ARRAY_SIZE = 4
tpl_code = 0xff
=====>>INSIDE rtl8192cd_init_one <<=====
=====>>EXIT rtl8192cd_init_one <<=====
UINet_WifiInit(): wifi init succesful
UINet_WifiInit(): wlan0 efuse mac [44:33:4c:a2:47:e8]
[ECOS]RtkWifi_CmdId_Config(ap wpa2-psk-aes INNOVV_K2_47e8 12345678)
[ECOS]available_chnl:[1][2][3][4][5][6][7][8][9][10][11][12][13]
[2022/07/18 15:25:38][ECOS][PHY_ConfigTXLmtWithParaFile_new][TXPWR_LMT_88E_new]
[ECOS][PHY_IQCalibrate]
UINet_WifiInit(): setip=192.168.1.254 -
UINet_DHCP_Start(): isCli 0
[ECOS][DHCPELIOS]ERR:dhcpd_set_lease_conf: lease_time 30 sec
[ECOS]tmpLen=11, 60-
UINet_DhcpSrvCBCliConn(): ::isConn=3,ip=0x0,mac= 0: 0: 0: 0: 0: 0
UINet_DhcpSrvCBCliConn(): ::isConn=4,ip=0x0,mac= 0: 0: 0: 0: 0: 0
[ECOS]system call
command=fsipc -open 10063872 369497624
[ECOS]system call
command=fsipc -mount /sdcard
[ECOS]system call
command=hfs -p 80 -l 443 -s 51200 -to 20 -t 6 -ma 18890208 -ms 71680 -n 6 -r /sdcard -c -put -q query_devinfo -u -d -v 0x16121309 &
[31mERR:nvtssl_init(): [0mssl not supported
[31mERR:nvtssl_ctx_new(): [0mssl not supported
[31m[ECOS]hfs cyg_hfs_init(): [0mssl_ctx_new
hfs: listening on ports 80 (http) and 443 (https)
system call
command=msdcnvt 0x0053F6B4 0x000000B8 &
[ECOS]MSDCNVT port=1968
BackgroundWiFiOn 0 result 0
Mode {MOVIE} Close begin
[2022/07/18 15:25:39]SMediaRec_Close-B
Mode {MOVIE} Close end
-lens count=0
uiMovieSize = 5
GYRO OPEN Fail
GYRO OPEN Fail
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
CHK: 892, PhotoExe_CfgNetHttpPIP[0m
CHK: 3801, MovieExe_OnOpen[0m
ERR:TM_End() Exceed max TM array!
WRN:TM_Begin() Exceed max TM array!
[ECOS]system call
command=lviewd -p 8192 -s 40960 -f 30 -t 6 -ssl 0 -v 0x16051315 &
lviewd: listening on port 8192 (http)
EMR00 CARD11111111
CREATEFSSTRG111 ok [over0] fsk=0 !!
ERR:LviewNvt_VideoTsk() AddrY 0
pObj 0 OK!
CREATEFSSTRG111 ok [over1] fsk=1 !!
pObj 1 OK!
ERROR Round vfr -> 30!
if any EMR sec = 10
if any EMR sec = 10
DISK2SECond = 8047
noemrsize=46481136
emrsize=46481136
[SM] Media 3.0!!
[SM] ver =660_2017_1204!falign=0.
FL_MOVIE_GPS: 1
CHK: 140, UIMenuWndWiFiModuleLink_OnOpen[0m
MovieExe_OnFrontCameraFlip 0
ERR:SMediaRecFSStrm_ConfigureObj() SMediaRec Video Stream ID 1 is invalid!.
#0 ID #76 is starting ...
1=76, want=76!
TargetBitRate = 1843200 Bps!
ipl_id_0 movie flip_NONE
WaitDel !
calc=424, must=390, emr=24, used=0
reset PTS, fstskid=0
reset PTS, fstskid=1
[2022/07/18 15:25:40]
MovieExe_OnRearCameraFlip 0
CHK: 422, UIMenuWndWiFiMobileLinkOK_OnOpen[0m
start rec led flick
send locate failed 01
[2022/07/18 15:25:41][ECOS]Auto channel choose ch:1
gNHC_filetype = 8!
normal pathid=0,=A:\INNOVV_K2\VIDEO\20220718_152541_F.TS
thm=0xa3a919a0 0x2362
[0] name=A:\INNOVV_K2\VIDEO\20220718_152541_F.TS
kick[f0]
AP ready, total period = 4072655 us
[2022/07/18 15:25:42]CHK: 289, Save_MenuInfo[0m
[2022/07/18 15:25:47]uWifiOnTimeCount=1[0m
[2022/07/18 15:25:57]uWifiOnTimeCount=2[0m
[ECOS]BIT(11) of 0xd2c = 1, 0xd2c = 0xcc979975
wlan0: WPA2-AES PSK authentication in progress...
4-1
UINet_StationStatus_CB(): wlan0: A client(76:BB:E1:CE:B3:70) is associated
[2022/07/18 15:25:58][ECOS]4-2
4-3
[ECOS]4-4
wlan0: Open and authenticated
WPA2: 4-way handshake done
UINet_StationStatus_CB(): wlan0: A client(76:BB:E1:CE:B3:70) is port authorized
UINet_StationStatus_CB(): ********** currentMacAddr 76bbe1ceb370
UINet_StationStatus_CB(): ********** gLastMacAddr 76bbe1ceb370
CHK: 623, UINet_StationStatus_CB[0m
UIMenuWndWiFiMobileLinkOK_Authorized_OK
[2022/07/18 15:25:59]UINet_DhcpSrvCBCliConn(): ::isConn=1,ip=0x2101a8c0,mac=76:bb:e1:ce:b3:70
cmd:3016 evt:0 par:0 CB:801df5a8 wait:0
[2022/07/18 15:26:00]cmd:3031 evt:0 par:-1591721428 CB:801df7e0 wait:0
cmd:3002 evt:0 par:0 CB:801e0238 wait:0
cmd:3022 evt:0 par:0 CB:801de880 wait:0
cmd:3001 evt:8000e012 par:1 CB:0 wait:1
cmd:3014 evt:0 par:0 CB:801de08c wait:0
cmd:2016 evt:0 par:0 CB:801de7d0 wait:0
cmd:3037 evt:0 par:0 CB:801de62c wait:0
cmd:3024 evt:0 par:0 CB:801de730 wait:0
[2022/07/18 15:26:03]cmd:2001 evt:8000e003 par:1 CB:0 wait:4
CHK: 558, UIMenuWndWiFiMobileLinkOK_OnExeMovieRec[0m
UIFlowWndWiFiMovie: Already doing recording!
[2022/07/18 15:26:06]cmd:3016 evt:0 par:0 CB:801df5a8 wait:0
cmd:3030 evt:0 par:0 CB:801dea90 wait:0
cmd:3029 evt:0 par:0 CB:801ddaa4 wait:0
cmd:2001 evt:8000e003 par:0 CB:0 wait:4
WRN:LviewNvt_StartDaemon() Already opened
[0]SMediaRecTS_GetAllLasting()
[ECOS]recv time out: Connection reset by peer
[0]SMediaRecTS_PutAllBSQ2Card size=0xb52ec
[0]stillBlock = 1
[1]SMediaRecTS_GetAllLasting()
SMediRecTS_GetAllLasting[1]waiting hit do nothing ok44
activeid=0
Setpath=A:\INNOVV_K2\VIDEO\20220718_152541_F.TS,size=0x30b52ec!
ERR:MP_H264Enc_setInfo() Multi-frame encode err!
no file[0] to end
no file[1] to end
[2022/07/18 15:26:07]ERR:Note_Ae_Init() AE Table 1 is not support.
uWifiOnTimeCount=3[0m
Call Stop callback 1
stop rec led flick
[2022/07/18 15:26:08]CHK: 558, UIMenuWndWiFiMobileLinkOK_OnExeMovieRec[0m
UIFlowWndWiFiMovie: Already in live view state!
cmd:3017 evt:0 par:0 CB:801de92c wait:0
XML_GetDiskFreeSpace(): FileSys_GetDiskInfo(FST_INFO_DISK_SIZE) 31998345216
cmd:3012 evt:0 par:0 CB:801defe0 wait:0
cmd:3034 evt:0 par:0 CB:801de4e8 wait:0
[2022/07/18 15:26:09]CHK: 289, Save_MenuInfo[0m
[2022/07/18 15:26:14]cmd:3028 evt:8000e028 par:2 CB:0 wait:0
[2022/07/18 15:26:15]CHK: 892, PhotoExe_CfgNetHttpPIP[0m
[2022/07/18 15:26:16]cmd:3021 evt:8000e021 par:0 CB:0 wait:0
[2022/07/18 15:26:17]cmd:3014 evt:0 par:0 CB:801de08c wait:0
uWifiOnTimeCount=4[0m
cmd:3005 evt:8000e013 par:-1591721428 CB:0 wait:0
cmd:3006 evt:8000e014 par:-1591721428 CB:0 wait:0
cmd:2019 evt:0 par:0 CB:801e00ec wait:0
cmd:3019 evt:0 par:0 CB:801de8c8 wait:0
[2022/07/18 15:26:18]cmd:3030 evt:0 par:0 CB:801dea90 wait:0
cmd:8004 evt:0 par:0 CB:801de484 wait:0
cmd:2009 evt:0 par:0 CB:801de9c8 wait:0
cmd:1003 evt:0 par:0 CB:801dea2c wait:0
client request 51779 ms
[2022/07/18 15:26:23]
send locate succes 00
[2022/07/18 15:26:24]cmd:3028 evt:8000e028 par:1 CB:0 wait:0
[2022/07/18 15:26:26]cmd:2025 evt:8000e033 par:8000 CB:0 wait:0
uWifiOnTimeCount=5[0m
[ECOS]sendall: Broken pipe
error len = 0x44, writeBytes = 0x0, client=9
client disconnect, time= 60248 ms
This is start up with front camera in front port and rear in rear port. Flashing lights as in original post video.
[2022/07/18 15:43:58]
NOVATEK SDK
Hello, World!
System Boot begin
LD VERISON: LD_NVT
cpu2 power on ready
[ECOS]
uart main return 0.
USB 1.5A
CONNECT to CHARGER
USB 1.5A
CONNECT to CHARGER
USB 1.5A
CONNECT to CHARGER
[2022/07/18 15:43:59]WRN:pll_setClockFreq() Target(4) freq can not be divided with no remainder! Result is 48000000Hz.
PS_DESC_BLOCK=1[0m
USB 1.5A
CONNECT to CHARGER
System Boot end
On Boot begin
----------->SENSOR_ID_2: 1 bResetStatus:0
MovieExe_OnGPS
UART2: Open success
ERR:uart2_isr() UR2 P-OVR Err!
enable mask=00000003
ERR:uart2_isr() UR2 P-FRM Err!
WRN:pll_setClockFreq() Target(1) freq can not be divided with no remainder! Result is 36000000Hz.
-sensor count=2, mask=0003, attach=0003, disp=0003
-lens count=0
uiMovieSize = 5
[2022/07/18 15:44:00]
set uiMovieSize MOVIE_SIZE_DUAL_1920x1080P30_1920x1080P30
GYRO OPEN Fail
GYRO OPEN Fail
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
CHK: 1458, Movie_SetRecParam[0m
[2022/07/18 15:44:01]WRN:pll_setClockFreq() Target(2) freq can not be divided with no remainder! Result is 120000000Hz.
ERR:ChgMode_IMX322LQJVX1() ChgMode_IMX322LQJVX1 to 1...
WRN:pll_setClockFreq() Target(3) freq can not be divided with no remainder! Result is 120000000Hz.
ERR:IPC_WaitImeFMD2() id = 0 timeout 0x08000000
[2022/07/18 15:44:02]ERR:GSensor_I2C_Transmit() i2c ret = 2!!
-->DA380 get data:0
fileid:0
GYRO OPEN Fail
ERR:IPL_CTRLRunTimeChg() IPC_Flip timeout
ERR:IPL_CTRLRunTimeChg() current chg = 0x00000008 , current status = 0x00000100 id = 0
[2022/07/18 15:44:03]ERR:IPL_CTRLRunTimeChg() IPC_Chg_Load timeout
ERR:IPL_CTRLRunTimeChg() current chg = 0x00020000 , current status = 0x00000100 id = 0
ERR:ICF_FC_TimerTrigProc() trigger interval shorter than process time!! 1
[2022/07/18 15:44:04]WRN:MovieExe_OnMovieSize() should change mode
[2022/07/18 15:44:05]ERR:IPL_CTRLRunTimeChg() IPC_Flip timeout
ERR:MovieExe_OnProtectAuto() dual record, not support this option!
ERR:MovieExe_OnProtectManual() dual record, not support this option!
On Boot end
USB 1.5A
CONNECT to CHARGER
===================================== sensor plug [SENSOR_2]
SMediaRec_Close-B
[2022/07/18 15:44:06]ERR:IPL_CTRLModeProc() error Id = 0, cmd = 1, sts1 = 2, sts2 = 0
-lens count=0
uiMovieSize = 13
GYRO OPEN Fail
GYRO OPEN Fail
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
IPL_PATH_1: 0 IPL_PATH_2: 1
liveViewError :-85 0
Ç|¥¥Ê0^?´m»PW-á.{ºÝŒãFý×—žGÐ2Ï*éx{ˆ×ˆe
NOVATEK SDK
Hello, World!
System Boot begin
LD VERISON: LD_NVT
cpu2 power on ready
[ECOS]
uart main return 0.
USB 1.5A
CONNECT to CHARGER
USB 1.5A
CONNECT to CHARGER
USB 1.5A
CONNECT to CHARGER
PS_DESC_BLOCK=1[0m
USB 1.5A
CONNECT to CHARGER
System Boot end
On Boot begin
MovieExe_OnGPS
UART2: Open success
-lens count=0
uiMovieSize = 5
GYRO OPEN Fail
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
-->DA380 get data:0
fileid:0
GYRO OPEN Fail
On Boot end
USB 1.5A
CONNECT to CHARGER
liveViewError :0 0
liveViewError :0 0
liveViewError :0 0
liveViewError :0 0
liveViewError :0 0
liveViewError :0 0
liveViewError :0 0
AP start
[ECOS]system call
[ECOS]system call
[ECOS]system call
Network mod:0
[ECOS]sdio lookup 3
sdio lookup 4
funcs = 0x1
tpl_ptr = 0x0
tpl_ptr = 0x1000
tpl_ptr = 0x1000
tpl_code = 0x20
tpl_link = 0x04
tpl_data =
0x4c 0x02 0x79 0x81
tpl_code = 0x21
tpl_link = 0x02
tpl_data =
[ECOS]
0x0c 0x00
tpl_code = 0x22
tpl_link = 0x04
tpl_data =
0x00 0x08 0x00 0x32
tpl_code = 0xff
tpl_ptr = 0x0
tpl_ptr = 0x1100
tpl_ptr = 0x1100
tpl_code = 0x21
tpl_link = 0x02
tpl_data =
0[ECOS]x0c 0x00
tpl_code = 0x22
tpl_link = 0x2a
tpl_data =
0x00 0x00
tpl_code = 0xff
[ECOS]system call
[ECOS]system call
[ECOS]system call
system call
-lens count=0
uiMovieSize = 5
GYRO OPEN Fail
GYRO OPEN Fail
SetH264MaxQp[0]=2
SetH264MaxQp[1]=2
[ECOS]system call
EMR00 CARD11111111
pObj 0 OK!
pObj 1 OK!
if any EMR sec = 10
if any EMR sec = 10
DISK2SECond = 8047
noemrsize=46481136
emrsize=46481136
[SM] Media 3.0!!
FL_MOVIE_GPS: 1
1=76, want=76!
WaitDel !
