Just installed my K2 on my BMW K1600. I read plenty of reviews and watched videos on the unit. Seem like great unit. I ran it for the first time today. It seems to be that the video so pretty washed out. Is this normal? Or i just the compression artifacts? I am not looking go pro footage but this seems not so clear. Look at the yellow lines Them seem to be over exposed
I noticed the same issue on my videos. I wonder if anyone has tried adding any photographic filters to improve the video quality (polarizing filter, UV filter, etc).
I am pretty sure that the effect you call "washed out" is due to compression artifacts. In your picture you can see, that the trees on the left side are a little bit blurry, too.
You can check out my modified firmware, which increases the bitrate.
https://www.innovv.com/forum/innovv-k2/modified-firmwares-with-higher-bitrates
