What video editing software do you use? I only want to use a 60 second segment from one of my 5 minute files and need a simple way to do this. Can you help?
Any of them will work. I had adobe at one time but it was to complicated. I use cyberlink now. I think it was around 60 us. Stay away from wondershare. Make sure you make a copy because one you edit it it strips out the gps stuff.
I put the full video file onto Dropbox, then transfered it to my iPhone Photos. Once in there I opened the full video and there are sliders on each end of the clip in Edit mode and hey presto the clip I wanted.
For simple cutting I use avidemux.
http://avidemux.sourceforge.net
It is easy to use and very fast, as it really only cuts the video without re-encoding.
For editing (cutting, adding effects, PiP and so on) I use kdenlive.
https://kdenlive.org/en/
Dashcam viewer is really amazing for seeing all the data together, and there's limited editing as well. https://dashcamviewer.com
I managed!
Dashcam viewer is also a good editor and is compatible with INNOVV's products.
Specific operation you can click the link here:
https://innovv.co.uk/wp-content/uploads/2018/09/GPS-Guide-K2-3-2.pdf
