K2 was working fine one month until 09.09.2018 Led's are blinking and no wifi connection to unit. I tried to reset K2 unit but no change. I uplouded a video (Stopped working.mp4) of blinkking rate.
Rear camera shows same video in several recordings. Wondering if rear camera failure is cause of K2 failure or is it only sympton of failure.
You can find the ports on DVR printed F & R, F- front camera, R- Rear camera.
The camera system can work if the only camera plugged into the Port printed F.
So you can plug one of two cameras to the port printed F and power on camera system, to see if it can work properly.
Working fine when only front camera plugged in.
Two cameras are exactly same, the only difference is the cable length, one is 3 meter, other is 1.5 meter.
So the front camera is 3 meter one?
If so, the rear camera needs to be replaced.
Yes, front camera cable is 3 meters and rear camera cable is 1.5 meters.
Thanks for update, you can see our guys have sent you the message to replace the front camera with 3 meter video cable.
You ment rear camera with 1.5 meters cable, right ;)
To avoid misunderstanding, can you confirm the video cable length from the above camera you mentioned?
Faild camera is rear camera and cable isiso 1.5meters long.
Get it, that this camera with 1.5 m video cable plugged the port printed with F does not work.
Our guys will send you email to arrange the replacement.
Got today my replacement rear camera. istalled, tested and working. Thanks to all
