I am very happy with my INNOV-K2 that has been on my bike since I bought it on 25th June 2019, I'm getting even more fun from it since I've mastered the basics of a video editing piece of software.
My problem is that the speed regularly does not display, in fact it is rarer that it does display. This is frustrating as it's like one of those intermittent hard to find problems. I get a solid GPS light on the unit and the remote module has a nice clear view of the sky.
So any ideas how I can fix this?
I had the exactly the same issue and after sending everything back to the uk office they gounf the Gps to be faulty. I got a new gps and everything works perfectly now.
I dont want to take everything out! Perhaps I could try a new GPS Module?
Mine was still under warranty at the time. I didnt send the cameras back and its easy enough to remove the gps unit on my versys 1000.
Hello David,
You can check to see if your phone's positioning function is enabled after you have ensured that the GPS module is installed in a position conducive to signal reception. If everything goes well and the GPS is still not properly connected, you can contact us or your dealer for a new one.
Thanks. I got some things to try from my direct contact to you so I’ll try these ideas to see it it works.
I’ll keep you all appraised.
Today I:
Cleaned the GPS contacts.
Unraveled the rats nest of GPS cable and stretched it out
Re-positioned the GPS unit
And hey presto it worked great today. I will reserve judgement that these actions have resolved my issues because it has worked intermittently but so far so good!
That's good!
Sometimes the GPS doesn't work because the signal isn't getting through, and you can make a successful connection after a few tries.
