Also, even with the speed turned off in the app, the speed data is still recorded in the metadata. The "show speed " menu item governs whether the speed gets stamped onto the video. Even with that turned off, if you use something like DashCamViewer software to play the footage, it will be able to show your speed.
You can see the speed control switch.
Switch it off, the speed will be 0, but you can see the riding route.
Many thanks, found it
