Jan 30
{SOLVED} Android app not recognising established wifi connection
27 comments
Edited: Feb 4
Hello,
I just finished the instalation of the K2 on a 2018 R1200GS.
I updated the frimware to the latest version aivalable on your website and I installed the latest app version on my Oneplus 6T (Android 9.0).
I can see the Wifi network Innovv_k2 and the phone connects to the DVR.
But after starting the app it does not seem to recognise the connection and keeps stating that there is no connection.
As the app does not see the connection I can not controle the dvr remotely and no settings are displayed.
Any help would be appreciated.
Herman.
same phone
please put it airplane mode then turn on wifi... it will work.
Feb 4Edited: Feb 4
Hi Andrea, many thanks for your reply.
I tried the airplane mode but that did not help.
In the mean time I found the DVR and camera's fully operational on inserting a 32 GB Micro SD.
The problem that remains is the fact that I can not configure the DVR or format any larger SD card due to the app missing the wifi connection.
I read something on this forum related to the Google location service and I will try this out and report back.
This is strange, in my case using airplane mode and then turning on only wifi (leaving airplane ON) makes me connect to the camera.
Feb 4
Andrea, I will try it again today and report back. I would like it to be solved this simple....
@hermanh I agree with you. I believe latest android version changed something and INNOVV app should be updated consequently.
Please write to support, it seems the forum is conveniently addressed only some times.
Feb 4Edited: Feb 4
Everything working fine now.
Thanks for your help Andreas.
The culperit seems to be the location service.
I put the phone in airplane mode, switched on wifi and the the location service. The app now works as advertised.
I'm happy the problem is solved.
Hi my friend. I have a similar problem. I want to ask you a question: look my picture , it is the same problem that you have to? I have an Android too.
yes, why don't you try what I suggested? it worked for me, but of course... i'm not affiliated with innovv, i can only share my little and personal experience
Feb 9Edited: Feb 9
Hello, I had a different message. Nothing about camera initialisation. Simply a message from the app asking to connect to the network while the phone was connected to the Innovv network. Try a search on the forum. I remember having seen a comment on the message you got while searching the forum for my problem.
Hi,
I have the same issue with WIFI........ ( BMW R1200GS Adventure 2018 )
The DVR is getting power and I cant connect to WIFI (phone does not recognize the DVR WIFI)
I have tried 4 cellphones (same issue)
I connected the DVR directly to USB with powerbank and still does not recognize WIFI
Where is the problem ?
Thanks,
Alex.
May 13
The issue was not caused by power supply, it is the problem from WiFi connection.
Please follow up below procedure to check,
1. Delete the App and redownload it, and enable all requirement the App asked for, like GPS location and others.
2. Set up phone to Airplane mode and enable WiFi.
3. Connect Mobile phone to Camera via App again.
The issue was caused by defective front camera , when i switched between rear & front everything start work. (wifi is activated and DVR connected)
you need to mention in user manual that if front camera not connected or defective dvdr will not connect.
DVR will invisible for phone if camera not connected to FRONT CAMERA SLOT.
Thanks.
Added to the 'Top Tips' thread.
Cheers.
Hi,
since I updated the application to new version 1.2.9  (also update  the phone to Android 9)
connection problems back again ...... Phone to DVR wifi connect with no problems
application not recognizes the connection   (no connection in application)
i tried with airplane mode and without  (app no connection)
Not working  -          Oneplus 3T - Android 9
Not working  -          Oneplus 5 - Android 9   Working -                 Xiaomi Pocophone F1 - everything works good
Where is the problem?
Thanks,
Alex.
May 26Edited: May 26
Similar problem on my Samsung Galaxy J5 2017 with Android 8.1.0
Firmware 0.49 loaded in the K2.
App version1.2.9 on the phone crashes continuosly.
Same firmware with APP 1.2.7 is working.
Tested with and without Airplane Mode.
Tested also with and without Location enabled on the phone.
May 27
As I have also reported here somewhere, I am also an affected user.
Today, after trying the new app update, I succeeded in getting connected with another phone, but not from my usual Samsung J5.
I too am in a similar situation now, which is disconcerting since everything was working great!
The DVR connects to WiFi in phone, but when I open the app (latest version) it always crashes immediately. This is in airplane mode, cell off, which used to be fine. App opens fine if DVR is off. I tried the reset button, different mem cards ( loaded with newest firmware) but still nothing.
It will record video on my 128 card, but at all the default settings and GPS is not recorded (light stays blinking). Wish there was another way to access the settings and at least get the DVR set up right. Could a bad GPS unit be causing?
I also have problems with v.1.3.0 on my Android Samsung A5. The app keeps stopping so I can't check anything. My I pad does work so I now know that the firmware upgrade worked and both cameras work. The wife's I pad also works. However,my wife's Android phone doesn't work and that is a Nokia 8. It keeps searching for an ip address but I haven't tried either phone in airplane mode. My A5 phone used to work before the app upgrade.
I followed all the above steps on 2 different Motorola phones (G3, G5) with different OS, and even though the app worked fine for months, it will only crash now if wifi is connected: "INNOV K2 Keeps stopping" pop up. There is no problem connecting the wifi on airplane mode.
Tried my son's OnePlus 6T, and it works normal. Records, and I was able to change settings to what I wanted. I can access the K2 with the Moto phones using the direct browser links Frostie provided.
Not sure if related, but my GPS doesn't work, even trying a second new receiver from a friend.
The app on my Samsung A5 keeps crashing, showing INNOVV K2 Keeps stopping, and in airplane mode it won't connect. My wife's Nokia 8 works ok in airplane mode.
Not only is it working on my Samsung A5 phone, it is also working on my two Samsung tablets, Tab pro 12 (SMT 900) running android v 5.1.1 and Tab S2 (SMT713) running android 7.0. And you can't even access the app on google play store with either of them. A nice result - many thanks.
I'll wait for the official release on Play Store.
Thanks.
That file is no longer in dropbox ...
New Posts
  • Loving this product so far. Question is: I'm a dual-sport rider and often take my GS Adventure offroad. How does the K2 hold up in rocky, rough riding environments? Heading back to Baja next month, and I would love to have it fully functional but I'm considering leaving the DVR back at the hotel. Advice?
  • I just completed a 14,000 Mile trip through the US, Europe, and a good deal of Asia. The entire trip, the Innov K2 was running, and capturing video. During this timeframe, my Sena Momentum INC Pro helmet's camera failed, so I was left with just the Innov K2 to capture my trip. In my case, I ride a 2015 BMW GSA, and the control unit for the K2 is installed under the seat, attached to a power distributor. The unit was installed at the BMW dealer in Charlotte, by a Tech that I really trust, and who did an excellent job. First of all, this thing (the K2) was bulletproof. It started and stopped, just as expected, each time I started the bike, and it never missed. The video quality when riding more slowly, was exceptional, but the quality when riding faster is slightly less than perfect, but still very good, and certainly acceptable. I used a 256 GB SD card, class 10, and I never completely filled the card, although we rode some days, as many as 16 hours, and 400 miles. Pls keep in mind that riding in Russia, Kazakhstan, Kyrgyzstan, and China will be on severely compromised roads, so our average speed was lower, and a 400 mile day is a very long day. While I love this camera, there are a few areas that need to be addressed. 1) I needed to have a set of tweezers with me at all times, in order to remove the SD card so that I could download the video. 2) The spring mechanism that holds in the SD card is strong enough that, on one occaision, it shot the SD card across the chamber that is under the seat, and the SD card ended up lost, somewhere in the body work of the bike. 3) The rubber cover that covers the SD Slot is too fragile, and it broke. This rubber piece has a tab on one end, and from opening up the cover, and closing it twice each day, the rubber piece broke, and made it much more difficult to get at the SD card. I'm going to need a new rubber piece sent to me. 4) Because the connector ends on the camera are as large as they are, the installation onto the bike was more complex, and more costly than I could have imagined. It was simply not possible to "slide the cable head through the cable channel on the bike", so the tank had to be removed, along with all the body work, in order to run the wires properly, in the wire harness channel. 5) I was unable to get the unit to accept the latest F/W upgrade, so I'll need to figure that out, once the bike arrives back in the US. 6) After installing the new app on my IOS device, I needed to delete the app, and reinstall from scratch, in order to have it connect to the WiFi network broadcast by the K2. These issues are relatively minor, but a bit annoying. So, they need to be fixed, but we cannot overlook the conclusion that this camera system is fantastic. Numerous times during the trip, someone would say to me that they thought that I did something, or wanted to know if I recorded an event that happened, and because the camera automatically starts recording, my answer was always yes, and I used the video to show what happened numerous times. I also used the video on my Blog, on a number of occasions. So, if you're interested in seeing the quality, you can visit www.motocliffnotes.info and look through the videos. You'll quickly find those that were recorded using the K2. And finally, because the front and rear cameras record to files, which are started and stopped within a 1/0 of a second of each other, I was able to easily build files which had picture in a picture, using Adobe Elements Premiere 2018. You really should look at some of these videos. The F+R views are compelling. This system is awesome, and I can't wait to use it again, for my next trip. How do I go about getting a replacement cover, for the recording unit? Sample videos of PIP https://www.youtube.com/watch?v=3kHYN1EyoWU https://www.youtube.com/watch?v=J-KbJL4oOa0
  • Would it be possible to have the DVR clock use Zulu time/GMT? I'm a 24-hour-time type of person. I would rather the system time and filename timestamps were in 24-hour format, vs. remembering whether DST applies or not. This would also eliminate timestamps that are an hour off, because DST changed but I haven't connected the DVR to the K2 app lately.
  • w-tbird
  • w-facebook
  • w-googleplus
