Hi, installed the K2 on a Road King. Each time I go to the settings screen it shows for 1 second and then crashes. We only have apple products, so tried it on iphones 6, 7 and 8, and on Ipad, but immediately goes off once loads up. I can access the camera and other spots, just not the settings so I can format the micro card (have tried getting to settings both with and without card).
Is there something different to do to get the settings screen to load?
I have also deleted the app and reloaded it. I looked through the forum, but didn't see this issue discussed, so if it is sorry for the additional ping.
Thank you,
There is interference for stable connection between mobile phone to camera system.
Set your phone to airplane mode and enable wifi connection, and connect phone to camera system, you will see it works.
BTW, do you mind to share your install? that will be good reference.
Sharing makes fun, Have fun and enjoy.
Rock
Rock;
Tried that, but no luck. I can see through the cameras but it opens the setting screen but immediately crashes. My neighbor does IT for a company and he has no idea why either.
So we unhooked it from the battery, deleted and then reloaded the app on the Iphones after making sure each Iphone was updated, deleted and reloaded the app on the Ipad.
Still comes on for just a second and then immediately to the device home screen.
We also turned off the house wireless internet to see if that was causing a problem, but isn't.
We are not using a VPN.
I don't see this as an issue for anyone else, so something I am doing is wrong, just not sure what it is. Any suggestions will be most appreciated.
Thanks,
For install:
I used an electricians 1 inch insulated clamp to hold the front camera, for those interested. I have driven over rough roads with it to see how it handled and it stayed focus, due to the rubber inner liner. So that fits on the front light bar without drilling. The rear camera is easy to mount, it was the front that took me some time to figure out. I will post pics.
@Bulag
That is the rare case.
Can you please click below link to download the last bin file to upgrade the firmware, and see if that can help. (Download bin file to the root of SD card, insert SD card to DVR, power on the camera system to upgrade.)
https://www.dropbox.com/s/9x6t4p4fa0ytxn2/K2.bin?dl=0
Meanwhile, the App developer will also help to check.
I'm having exactly the same experience on Android, with two different phones.
For Android phone, Click below link to download the last version of App, and test it to see if can get problem fixed,
https://www.dropbox.com/s/bpfocawgw08m7do/innovvkt-1.2.8_2019-03-27-05-30.apk?dl=0
More than that, save as the above, click below link to upgrade the firmware, and retry.
Hi Rock,
I have the current App version on both my Android phones - a One Plus 3T and a Motorola X Style. The App version is 1.2.8. I've also upgraded/reinstalled the firmware to the K2 - the version installed is K2 20180925.
I've now been able to use the App on both phones to check/update settings so as far as I can see the problems I have been experiencing have now been resolved so I'm now a happy K2 user.
Regards,
Cliff
Rock
Apple just released an update. My settings screen still crashes so I wanted to see if you all will be doing an update?
Harley doesn’t make removing the tank easy so before I pull the camera off wanted to check if an Update was coming that may fix my issue
thanks
Mine used to work, now have app crashing issue on settings. Rebooted, reset it, removed power at rage during connector, used usb. no luck. This all started with new memory card, told me format is wrong but it’s recording. Tried the old card and no card same issue.
Reloading 61 firmware fixed the app crashing issue in settings. still have issues a crashed recording then no recordings after 10 minutes on bike, and the dvr Turns itself off within seconds when I go to check it, then eventually it works again. I will spice some longer wires and move it further from exhaust. currently is under the seat on a 1299 panigale, i‘m reading ~130F+ degrees. So it’s close but within spec.
im having the same issue with settings crashing need help
I had to reload the Firmware to get around the crashing issue.
ill try that tommorrow thanks just use last update which i think is K2-V70....
That should work. I’m probably running something a little older.
I reloaded the newest version on all of the family phones and still crashes on all of them
tried a new SIM card also
i just can’t figure out what is not working
I installed the K2.bin file and settings stopped crashing and im able to set up. only problem now is camera shots are 180 degrees out (upside down)
Updated with the k2.bin and reloaded again and just not working
I get video and camera but have no control over them so each video is very short and shows the bike going 212 km/h while parked
I think the idea is good but just can’t get it to work so removing from bike
did you use a small under 32 sd card i read it wont take with something higher than that
You were correct! and thank you. I used a 32gb card and could get to the settings screen. Tried some bigger cards after that but all of them crashed, despite being FAT 32. So that is the key. No bigger than 32 gb. Thank you after a year I get to use it
My app is doing the same thing. It was working but now its not. I will try with a 32GB card to see if that has any impact, but its working with my wife's DVR, just not mine.
It was working on my K2 with a 256GB card, but my wife's card died in her unit so I moved my card over to her unit, set hers back up, then tried to get into the settings of mine and it crashes. Deleted the app, reinstalled the app, and same deal.
Im running an iPhone with the latest update and latest Innovv App. I hope the new card and/or re-flashing the k2.bin file will resolve. If not Im going to be screwed.
