I have just started using a 128gb sd card and, when checking to make sure it is working correctly, find that there is only one folder on it labelled "Video". All the expected files are there but no "Park" or "Locked" folders. The card appeared to format correctly but I have disabled the G sensor, as it is too sensitive. Does disabling the G sensor stop the folders from appearing as they will obviously not be required?
