Hi all ... how many hours of vid (1080, front and rear) should I expect to store on a 128g card?
Thanks
At 1080p a 15 min video takes 1,4GB for each camera.
Therefore with a 128GB SD Card you can store a little bit more than 11 hours.
Awesome, thanks
Am I correct in assuming that once the SD card is full then the older files are over-written by the latest recordings?
If Loop Recording is enabled, which it is by default, the oldest files will be overwritten by the latest files. Otherwise recording will stop if the card is full.
Thank you Frostie.
