Hi all,
today I did the second trip with the K2 installed and wanted to test the 720P resolution. So I switched on Ignition, waited for the K2 to power up and changed the resolution to 720p using the K2 app. Then I started driving. During the trip I made a short stop with the Ignition turned off.
Back at home I checked the SD-card, but there were only files in 1080p.
- One short file in 1080p from the moment I turned on ignition till I changed the resolution
- Some 1080p files, starting from my stop on the trip.
So the K2 stoppped recording after I changed the resolution to 720p.
Later on I checked it again and set the resolution to 720p. But after powering off and on, the resolution is reverted to 1080p. I also tried to provoke the K2 to save the settings by changing other settings (e.g. turning GPS on/off), but that did not work. The other settings are saved, but not the resolution
Firmware: K2.20180925.V0.39 (was already installed when the K2 arrived)
App-Version: 1.1.4
Any suggestions what to do?
Regards,
Frostie
Perhaps someone else here in the forum could check whether he/she can switch the resolution to 720p or not? Just to see if it is a general problem or just related to my K2.
Well noted this issue, will discuss with the App developer, and keep you updated.
