I always try to keep spare fuses for items. Sadly, local stores only go as low as 2 amp. I'd only want 2 or 3 spares. I don't think it would be wise to supplement with a 2 amp fuse when 1 amp is the norm.
Is it possible for a couple of spares to be sent? Stores in my area only go as low as 2 amp, and I did order mini-fuses for my power distribution block in 1 amp, but no full size ones.
If your local dealer does not have 1 amp fuses, why don't you order some at e.g. amazon?
https://www.amazon.com/Amp-Black-ATC-ATO-Fuses/dp/B00NV7S4HK
2 AMP fuse is acceptable, but we recommend a 1 AMP fuse to be the safest.
