Residential electricity in the United States is supplied at 120V ac and 60Hz.
We recommend that the rider set the recording time to 3 minutes or 5 minutes, because 10 minutes of video quality is too high, when you want to download this video, the speed will be slower, 3 minutes or 5 minutes is the best choice.
The g-sensor is set to low by default.
If the setting is too high, the video will be locked and saved in the parking file when your motorcycle has a slight vibration.
A 64GB or 128GB SD card is recommended, and the grade of the SD card should be class 10 or U3.
What kind of custom settings you do need?
Should I be 50 or 60 hertz? Recommend loop times (currently at 10 minutes), G-force sensor? SD card size/type that works well, etc.
@Rick Wyatt
