i have just switch my system to another bike but system boot with fix green light. after flash firmware i have a sequence boot but system reboot after few seconds. sequence is
green
blue - green - orange
green - orange
fixe green
and restart
i have tested with only front cam = same
i have tested with only rear cam = same
i have tested with rear cam on front port = same
it's the same boot with usb 2A without any cam
is it a cam issue?
have you any ideas about that?
i have tested the 3 firmware on website
i just had such a problem recently, and my local dealer's tech guy was able to plug one camera unit at a time, and by using elimination - deduce that the front camera cable most likely was damaged.
i then purchased one remaining front camera set - and did the replacing by myself. true enough, there were what looks like burn or melt marks on the cable exterior.
my guess is that when the camera was installed by a bike store for the earlier owner of the bike, the excess cable was tucked outside the underseat storage of the scooter. and as you know, the burning hot engine isn't too far away from the sort of loose cable.
Sorry for the late reply. I was quit busy the last days.
I supposed IPL_PATH_1: 0 IPL_PATH_2: 1 is cam detection and need to be at 1 for each
That's correct. It seems that your DVR does not detect a cam at the front port, so it restarts in its efforts to find it. Either because both cams are broken or because the front port is broken.
I flashed my spare K2 with the V70 firmware and did some logging for you for comparison. You can find the files below. With the front cam disconnected, I get the same error messages as you. Especially the liveViewError :-85 0 at the end of the log, right before it does a HW Reset. You can't see the HW Reset in your log, because your K2 did not finish the log file. I took the log via a direct connection the the DSP, that's why I get a complete log.
You could try and install a special firmware which enables logging. The log could help finding out why the K2 reboots.
You can find the firmware in my dropbox.
At each start the firmware writes some dump files to the sd card, which are useless for you. But beside the dump it creates a text file for each start which contains the log.
Hello David, Sorry for the problem you met.
When you power the DVR with a power bank or wall charger, please connect the front camera only or connect the rear camera with the front camera port and see if it works.
