Is there an easy free video editor available for Windows to create the PIP effect (like the K2 Ride at Sunset and Night video by David Cappelaere)?
I have downloaded a few only to be disappointed. Any suggestions?
Also, my GPS receiver did not function at all straight out of the box. Fortunately Innovv said they will send me a replacement which I look forward to receiving (good response). Has anyone else encountered this?
I have had corrupted video files which is a pain so will format the SD card and see if this helps.
What have you tried up to now..
I cannot remember sorry, but I downloaded Filmora and Video Editor yesterday, after doing some more research, to try when I get home from work which is unfortunately another 4 weeks away.
Dashware was recommended on this site at one time.
Thanks for the info :-)
Dashware...Very interesting program, many uses/options, Free, Have already downloaded a copy, but I do not think it has picture in picture capability.. It will support a video that already displays pip, but will not add pip to video by itself...
OK wasn't sure. I use my current video editing software that I purchased. (Corel Video Studio)
MAGIX Fastcut, try this one also.
Thank you for your response Rock.
I will look for MAGIX Fastcut.
All wiring connections are exactly as they should be and yellow is soldered to a switched power source. GPS logo is up (photo sent to Felicia Chen) and in a clear line of sight with the sky. GPS app settings are switched on.
I have tried disconnecting/re-connecting, power cycling etc. Nothing I've done seems to initiate the GPS.
@Dean Oxwell
Well noted, As Felicia promised to send you new GPS, for sure, you will get it.
Thank you Rock for your comments and assistance. I appreciate it.
I am not in a position to connect to my camera system for a few weeks (I work away from home) but I had a look at the settings from the INNOVV website for the K2 app and did not see a GPS On/Off setting. I did see a map setting though, which is set to Google maps.
Unless they have changed it with an update, after selecting settings look to the bottom of the first set of selections, last option just above the memory card section... it is possible that you may have to connect an operational GPS unit for that selection to show up...
As with Dashware, I do not believe MAGIX Fastcut does PIP... Still it appears to also be a impressive program...It is also free after after 30 day trial with limitations...
Thanks for the feedback Waren. I don't recall seeing that, but I could be wrong. My GPS never connected and the LED just kept blinking so that may be the case. I spoke to the good lady at home last night and she told me it looks like the replacement GPS has arrived so I will put it to the test when I get home at the end of November.
Thanks to INNOVV for sending the replacement :-)
RaceRender 3 is the software I use for Picture in Picture PIP. http://racerender.com/Products/index.html
An example I made using Innovv K2 and RaceRender3 https://www.youtube.com/watch?v=BV9-s4yx7tE
We have sent from emails to RaceRender for cooperation, but without reply so far.
They made great software for racing.
Thanks a lot Mike and Rock. I've just downloaded the free version of RaceRender3 and will have a play with it. :-)
You could also check out kdenlive. It is a video cut- and editing tool, but you can easily make a PiP with it. The Windows Version is beta, but nevertheless it is worth a try.
HI All, I'm new to this forum so apologies if i'm cutting through any protocols.
I have bought and successfully installed the K2 and wondered if there is any software out there that will allow me to create a video, show both channels and an inset if the GPS map. I go touring quite a lot and most of the gang I ride with are asking if it is possible without having to use a specific player, but just create an mp4 with all 3 on it so it can be viewed on any player.
any ideas, suggestions?
Stuart
Hey Lean, for now, one video editor that we recommend users use is the dashcam viewer, but it is only used for post-editing.
If you want to use this kind of software for real-time viewing, you can see if other riders in the forum can help you.
