I'll ask the collective board wisdom to see if someone else has experienced this.
I tested my K2 at 1080 @ 30 fps for 1-minute loops (to keep file transfer fast). I got 1-minute clips for the entire trip and people had some criticism as to the image quality. They suggested I repeat the test at 720 @ 60 fps and compare results.
Did so and came back with video clips not exceeding 15 seconds and of only a few minutes of the trip. I was communicating with the K2 via the iPhone app before starting and after finishing.
Any idea what's causing this? Thanks in advance for any help you can give.
What firmware version are you using? Maybe I can reproduce this behaviour and check the logs.
