hi . i turn on my bike and all the lights are ok on the device but i do not see the innovv wifi on my phone. i tryed swiching phones and i pad but it seems that the device is not transmiting wifi . any advice? no wifi signal is detected on my phone from the K2.
Can you post a short video of what the leds on your K2 looks like?
Is everything else running fine and does it record videos?
hi. thank you for your reply' the camera does not record ' nor does it send a WiFi single but all the light are on and it seems as if it is running ..it was running fine before..
first If you have a iPhone go into setting and forget the camera wifi. second delete the app from your phone and then install it again. Third disconnect the power wire completely from dvr for at least 2 minutes, this will cause a hard reset. If you are using a micro sd card more than 32gb remember you need to download a card formatter that will do fat32 format and format the card with your computer. Then after you have done all the above insert newly formatted fat32 card into dvr and (TURN ON THE BIKE FIRST) wait for blue blinking wifi light go into dvr setting and format your card. Next enjoy your camera ride
Your K2 is continuously resetting itself. That's why it does not start recording and does not initialize its wifi. One possible reason for the reset is, that the DVR cannot find the front cam.
So please switch the cams at the DVR and see, if it will startup then.
If not, remove all cams and start the DVR. It will keep reseting. Let it reset two or three times. Then switch of the power and connect the rear cam to the front port and test it again.
thank you . it worked. i just want to make sure in the next few days that it doesn't happen again. @Frostie
