. Hi . I have big problems with my K2. it has never worked as it should. the problem now is that it does nor reach wifi . i turn it on and there is no wi fi connection named innove. nothing.. so one some one here wrote that if the dvr dosent recognize the front cam it restarts itself and doesnt connet ' or rather doesnt reach wifi status .. so i disconnected the rear cam and it worked , it connected to wifi and recorded with the fron cam.. i then switched off , disconnected the front cam and connected the rear cam and turned it on again. it connected and recorded with the rear cam . as long as there was only one cam connected it worked. as soon as i connected both cams it didnt work and didnt get to wifi mode .. can any one tell me what the problem is and can be done? thank you .. yaad Comment Publish
On the K2 the WiFi is using the same frequenses as Bluetooth and the connection goes down as soon as you use Bluetooth. You need to turn off all Bluetooth which is almost impossible.
I had a K2 and I bought a K5 which is using 5g and it is stabile. i complained about this when I got my K2 2018 and I never got it to work.
The first thing should always be re-flashing the latest firmware.
After that you should try the cameras one by one at each port. Strange thing is, that you said the K2 started with only the rear cam connected. Because without the front cam, the K2 should constantly reboot in its efforts to find the missing cam. Anyway...check each cam to make sure they are both ok.
A video of the DVR, showing the LED at startup when both cams are connected could also help.
Just throwing something out there:
- maybe re-install the firmware? - have you reset the DVR unit? - have you tried the front camera on the rear port and visa-versa? Does it also not work then?
