Hello,
I wonder if you can help with a problem I've got on friends bike.
K2 camera system, worked great for around 2 years then has just stopped working.
I noticed that there was no light on the power converter, fuse was ok, so ordered a replacement.
I've fitted it this morning but still having a problem. The power unit flashes blue when connected and ignition on. Its solid blue when engine is off.
The K2 unit itself has no lights on it at all and appears not to be powering up, no Wi-Fi from unit.
Any thoughts much appreciated.
Brian
I am curious what the voltage of your motorcycle is when the engine is running. What happens if you feed the K2 with a power bank? So no power from the motorcycle.
And if you disconnect the rear camera, does the K2 turn on?
You can also disconnect the front camera and connect the rear camera to the connection of the front camera. This is to find out if one of the cameras is causing a problem.
