Hi, I'm already a long time a happy daily and 4 season user of my K2 camera system on my Honda Super Blackbird. :-)
Since the update of the app I don't have access to my camerafiles and configuration settings anymore. The app always mentioned that there's no wifi connection with my camera. But I have wifi connection to the camera with my smartphone and can see all the files via the internetbrowser on my phone on IP 192.168.1.254 So there is a perfect connection between the 2 devices.
I have also 30 minutes ago updated the firmware 0.64 of the camera, made a new connection, reinstalled the app, but all without any results. Problem stay's the same. :-(
I saw there are very short movieclips made, so the update is ok, just need to make the old settings back like before.
Can you suggest any tips or hint. Am I doing something wrong or is there a bug somewere? Thx in advance for any help ;-)
Kind regards Jelle
PS: I use Iphone SE with IOs 13.3
Nobody? :-(
Sorry, I don't know why your app cannot connect. But as a work-around you can make the necessary settings using your browser. It is a little bit cumbersome, but it works.
You can do all settings using your browser on your phone. The command is:
http://192.168.1.254/?custom=1&cmd=xxx&par=yyy
xxx = the function you want to set
yyy = the parameter
I made a complete list of all commands. Just take a look here
https://www.innovv.com/forum/main/comment/5ced8f3c4eabd200baeb908e
@Frostie THX !!! I'll try to make the connection and make settings with the browser, so meanwhile I hope with next update that the problem is solved! I know it's strange, but nog other sollution is found yet. I'll keep this up to date!
@Frostie Connection is fixed, but using an other way. putting de iphone in airplane mode => turn on wifi and than connect again with the DVR. Only than the app will connect with the unit. If else, the connection is ok, but only true the browser... Strange, but I made the necessary settings and still happy to go ;-) kind regards
