Firmware k70.
I have been able to connect to K2 via the app, however I am now getting 'WARNING - Camera initialisation failed, please insert two lenses again and restart camera. Or click cancel to try to enter pure preview mode'
I have replugged both front and rear cameras a number of times but still getting this message.
The camera is recording OK as when SD card viewed both cameras recording OK.
Any ideas please?
Try the search function in this forum with "initialization failed".
Or click on this link https://www.innovv.com/forum/search/initialisation-failed
I think you will get enough information to test further.
Good luck and hear if you have managed to solve the problem.
Try to uninstall the APP and download it again.
And check the connector between the DVR and converter, make sure they're connected stable.
Many thanks for your response, However, I have found the solution to the problem. I hope this will assist others. The solution was (on android) to switch airplane mode on, this of course disables cell and wifi networks, you can however switch wifi ON (whilst in airplane mode). connect to K2 in usual manner and you should now be able to talk to the K2.
This is also a method. Android can't access the Internet after connecting to the APP's WiFi, so flying mode won't cause much trouble.
The issue was a routing problem in the android, In normal mode (airplane mode OFF) and connected to K2 wifi, packets where being routed via the cellular network and not to the K2 over the wifi. for example ping 192.168.1.254 had no response. When airplane mode set to ON and wifi enabled and connected to K2, pings now get a response, and all works as it should.
