I have just installed the K2 on my GTR1400 & works great, but when on play back does not register the MPH on the video. Any ideas as all settings are correct & set up to go..
Hello Harry, may we know the working status of the GPS module? Is it working normal or not? Meanwhile, could you kindly upload the original video for a faster diagnosis of the problem? (If you do not want the video posted here, you could kindly send the video to help@innovv.com.)
@harry_lewis22 Thank you for your detailed reply here with photos. It seems that the GPS does not work from the photo you provided. Could you kindly take the DVR outside and make the INNOVV logo toward the sky? Then please kindly check the GPS led light status on the DVR. Meanwhile, we would highly appreciate that if you kindly send an example video to us via help@innovv.com.
I can't really see what's above your GPS antenna.
Is that for a top case? This can block your GPS signal.
I will move it forward to the back of the seat & see if that works. Thanks.
@INNOVV MotoCam
