I want to know what is the latency in Live streaming? Either through browser or the app? Is it usable as a sufficiently real time rear view device? This is my primary use on the BMW R1250GS as the rear view mirrors are far apart.
Around 1 sec when testing on the bench.
In my opinion...no, it is not. One reason is the latency. The main reason is that a WiFi connection in general is not reliable enough to entrust my safety to it. It could be easily interfered by other nearby devices (e.g Bluetooth headset).
The live view of the K2 (or of all Innovv cameras) is only intended for adjusting the cameras or checking its function, but not for permanent viewing or usage as an additional rear mirror.
If you want a rear view system as a replacement for the rear mirror, nothing beats a dedicated wired system.
Below is from google translate, not sure if that is correct to your question,
There is WiFi delay, but the video should not be in slow motion.
What phone and model are you using?
The WiFi set into DVR is under seat, and metal around DVR impacts WiFi signal transmit. You can open seat and do other try.
Hello, you can see directly what is being recorded on the mobile screen, I tried it once, the only thing that looks like the image in slow motion.a greeting
@Frostie
Thank you so much for your response. I was not able to get this answer from anyone. This clarifies a lot of things for me.!
My buying decision depends on this
En la aplicación esta la opción de ver los archivos grabados y si le das a la imagen de la cámara veras todo lo que graba.
Hola, se puede ver directamente lo que se esta grabando en la pantalla del móvil, lo probé un vez, lo unico que se ve la imagen como a camara lenta.
Un saludo
You can use the App to get a live stream of both cameras. Or you can use your browser by accessing http://192.168.1.254:8192
