Trying to set up K2 camera..Iphone 6 running 13.1.3. MicroSD Extreme128g.
Inserted card into DVR, powered up using phone charger. Phone is not seeing WIFI. Icons on DVR - wifi flashing 2 tmes then stops for 5 seconds or so, video icon green, flashes 2 times, then stops, camera icon flashes once, then GPS & wifi icons flash. This sequence keeps repeating.
Have tried in airplane mode and turning wifi on/off on phone.
SD card was inserted into DVR, without any formatting, had read DVR formats the card.
Laptop and ipad also do not see wifi signal.
Any help/guidance is appreciated.
Please confirm whether the WIFI on the DVR is flashing normally. If so, please install firmware and APP again and try again.
Firmware updates require SD CARDS in the format of FAT32.
1. download the Bin. file to the root of the SD card, make sure it sure have one bin file on the SD card, no bin(1) (2), the name of the file should be K2 bin.
2. insert the SD card to DVR, power on the camera and firmware update accordingly
3. see how the LED lights flashes the update complete
https://www.dropbox.com/s/355vvchsjh6g4hr/INNOVV%20K2%20Firmware%20update%20%26%20LED%20flashes.MP4?dl=0
Had same problem with my Iphone 6 plus, found out its my Iphone loosing its capability to find wifi and not the camera system
Time for a new Iphone
@kensDen Thank you for your kind feedback here.
May you have any other question, please feel free to contact us.
