I installed my K2 on my Triumph explorer. Took a few hours but only due to following the triumphs cable runs. K2 worked well for first day but now will not power up. I’ve checked voltages to red and yellow / switched and unswitched but the DVR will not power up. it will however power up via the micro usb. Have i got a faulty power hub?
Put lens R into port F no change, put lens F into port R no change.
put F into R and R into F at same time no change.
Put Yellow to Red no change!
Dc converter video showing blue light
DVR video when USB plugged in and ign on. No wifi available
Explain: what do you mean by ACC? Will try and put red and yellow together tonight, but if I’m already getting the same voltage with ignition on I can’t see how this is a remedy.
I would like to know do you have a blue work indicator on your converter? If yes, do the blue lights turn on when you turn on the motorcycle?
At the pins I have 5v at the yellow but only 1v at the Red!
