Yes, I would also like a better explanation of what all the settings are and what they do. I haven't been able to find one anywhere so far.
What is Time Lapse? Why is one setting better over another? What are the pros and cons of each?
Same for the Loop setting.
G-Sensor: I've seen this one asked several times and it's still not clear what the settings mean. Is the Low setting mean that the sensitivity is low and so it won't get as many false positives? Or does it mean that it is extra sensitive?
Hello, we are sorry to inform you that this feature is not available now. You could kindly change the video from .ts to .mpg with specific software on your laptop but the GPS data will be lost. Meanwhile, we will forward this request to our colleagues to follow up. May you have any other question, please feel free to contact us.
Their reply was mistakeable. The K2 supports two video formats.
MP4 with GPS data encode within one video stream.
The videos can be viewed with any video player, but if you want to also see or extract the GPS data, you need a special software like dashcamviewer.
TS without GPS data
There is no option at the K2 to get MPEG files with separate GPS data files.
Are you asking how to access the setting and make setting change?
refer below screen shots and see if those are helpful.
Click the red icon to access the settings,
Move down from the setting page to find the setting you would like to change.
It is simple and easy.
Yes that's fine and I've done all that, what I was after was a break down of what the settings mean.
Thank you
Have a look here.
https://innovv.co.uk/wp-content/uploads/2019/01/Copy-of-Get-to-know-the-Innovv-App-K2-1.pdf
How to set video format from .ts to .mpg with separate gps data files on K2? with android app.
Can't find any cmd to set Video file format on NT9666x chip. Are there any suppl. cmd for K2 not listed in the .pdf file above.
MP4 with GPS data encode within one video stream. The videos can be viewed with any video player, but if you want to also see or extract the GPS data, you need a special software like dashcamviewer.
TS without GPS data
