Loving this product so far. Question is: I'm a dual-sport rider and often take my GS Adventure offroad. How does the K2 hold up in rocky, rough riding environments? Heading back to Baja next month, and I would love to have it fully functional but I'm considering leaving the DVR back at the hotel. Advice?
When K2 is used off-road, we suggest that you need to fix the DVR and lens stably.
The DVR has shock absorbers inside, so the picture doesn't get too fuzzy.
Thank you. It sounds like the secure, interlocking velcro mounting of the DVR I have, along with the shock absorbing engineered into the DVR, the unit should be OK.
I have used my K2 off-road. Probably not as rough as Baja, but certainly rough enough to pucker up in some spots. The video on mine was fantastic. The GPS track was a wonderful thing to have after the trip since it provided a complete map of our all-day off-road trek. The DashCam Viewer software was great and very nice to be able to playback at higher speeds, have acceleration, azimuth, g-shock, velocity, and of course the full GPS map.
Some suggestions. As Rock mentioned above, be sure that the lenses and DVR are firmly mounted. Mine are not perfect, but as good as will ever be possible. Only under a few circumstances do I see some vibrations in the image. Not enough to tear or jump around. But just enough to know you are moving. This only occurs during highway speeds and specific engine RPM's. As for the DVR mounting, mine was originally taped to the bottom of the under seat box (but eventually the tape gave up) during that trip. There were maybe 30-40 x 1 minute files out of about 1,400 (~11 hours at 1 minute files for each of the front and rear) that showed some purple color and "vertical hold" video errors. These were all from the highway. I suspect it was vibrations momentarily breaking contact with the SD card contacts inside the DVR... Although based on later diagnostics, I believe there was also a power supply issue. After that trip, I secured the DVR with Velcro. I think this gave it the stability of not being able to bounce around, as well as a vibration "buffer" with the hook and loops that the tape couldn't provide. It also makes it easy to remove and replace the DVR to retrieve the SD card.
One more important piece of advice... unless you are the lead dog, be sure to wipe the dust off your cameras when you stop for breaks and such. I got a fairly good layer of dust on mine before I noticed. It did not ruin the video, but did make more glare when driving toward the sun. There was a noticable difference between sunny video and shady video. The effect was mostly eliminated after cleaning off the dust.
Thanks for sharing your experience. I mount my DVR with interlocking velcro as well - I've been able to finagle a spot where the SD is still accessible, so I really never need to remove it. I'm far less concerned with video quality than actually damaging the DVR through over-shock and vibration. But... we'll see how it goes.
@Hugh Velcro is a kind of fixation is also common among our guests.
@Grimmer have acceleration, azimuth, g-shock, velocity, and of course the full GPS map.
What is your idea about the parameters?
RPM, Gear, Throttle should get from CanBus, but the rest would like to add to the video.
You are right, the vibration can affect the tight pin contact between SD card and SD card holder.
Yes, that is be helpful.
Fixing DVR on motorcycle will be helpful for reducing the DVR movement & shocking.
Thank you for your detailed feedback and Suggestions.
Fixing the lens and DVR is one of the necessary conditions to ensure the normal operation of the system.
Have fun and enjoy!
Hi Guys,
My K2 is fastened to the area under the seat of my 2015 GS Adventure. I just completed 120 days in Asia and Europe, and the roads of Russia, Kazakhstan, Kyrgyzstan, and China are some of the most technical and daunting roads that I've ridden.
The K2 held up perfectly, no issues.
The front and rear camera are mounted firmly, to a strong/secure anchor point on the front and rear of the bike. I have not tried to apply absorption or shock reduction, so the installation of the cameras is simple, yet the video is still great.
Thanks for the feedback. And I'm supremely jealous of what sounds like a truly amazing trek.
