Hi everyone. I am having an issue with my K2. I have set the G sensor to OFF and loop video to 3 minutes but I‘ve noticed it went back to the default setting of the G sensor to LOW and loop video at 1 minute each time I start a new ride.
Am I doing something wrong or did I miss a step? Appreciate your response. 🙂
Just a thought - When you last flashed the firmware, did you then format the card through the app as the last part? Because if not could it be that with the firmware file (k2.bin) still on the 3rd every time you start the DVR unit it is reflagging the firmware so resetting back to default values? If that might be the case, if you are the latest firmware already then I'd frame the car through the app so then the firmware won't keep trying to refresh itself
Hmmm...could be an issue with the internal battery.
You could first try to flash the latest firmware and check, if this solves the problem. If not, you should contact Innovv Support at tech@innovv.com
