Is it possible to get an adapter like the GoPro tripod mount for the K2?
I would like to mount both camera's like a GoPro.
I allready have the tripod mounts but the thread isnt matching and before i drill in the mounting block i would like to ask this first.
I use GoPro mounts an bought Sametop Universal Conversion Tripod from Amazon. Not a fan of drilling holes in my bike.
@Peter Sandberg im not a fan of drilling either. The GoPro tripod mount is 1/4inch but the innovv thread is 6mm.
You say there is a conversion?
Going to look at those right away.
Edit; do u have a link to the right one?
Would make my search alot easyer.
@Nick Hillenius https://www.amazon.com/Sametop-Universal-Conversion-Adapter-Compatible/dp/B06ZYKXYQK/ref=asc_df_B06ZYKXYQK/?tag=hyprod-20&linkCode=df0&hvadid=309777532761&hvpos=1o1&hvnetw=g&hvrand=13419831046725165908&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9032047&hvtargid=aud-801381245258:pla-402424239019&psc=1&tag=&ref=&adgrpid=63226431993&hvpone=&hvptwo=&hvadid=309777532761&hvpos=1o1&hvnetw=g&hvrand=13419831046725165908&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9032047&hvtargid=aud-801381245258:pla-402424239019
@Peter Sandberg thank you very much, this wont require any adjustment on the original bracket that comes with the K2?
Nope. Worked fine for me and under $10.
@Peter Sandberg
Received the sametop adapter.
It goes in 1 winding and gets stuck.
Both threads are different.
Even a m6 nut doesn't go on.
Do i need a mount with 1/4 20 threading?
@Peter Sandberg would u mind taking a picture?
Or does the mounting bracket come with 2 different threads?
I do not know. I got mine over a year ago and the brackets was standard camera mounts. So it works. Maybe they have changed it now.
@Peter Sandberg thanks for your reply thanks for your reply.
@innovv had there been a change in thread?
I am looking for brackets that comes with 1/4 threads instead of M6.
Are those available?
@Nick Hillenius
It looks like the new mounts are not the same. Mine is sturdy.
https://www.ebay.com/itm/3-8-female-to-M6-male-Convert-Screw-Adapter-fr-rod-rail-system-Tripod-camera-/181785798716
@Peter Sandberg, thanks alot.
This makes it clear why my mount doesn't fit.
I know i can buy another adapters and spending more money to fit the camera.
I allready adjusted the mountains that i ordered from Ali express wich came also with 1/4 threading.
Made those to M6 but it left almost no threading.
I also talked with Jade Luo and got advised to buy the bracket that comes with the C
I also talked with Jade Luo and got advised to buy the bracket that comes with the C5.
I dont like those because the camera will rotate due to vibrations from the bike.
https://www.innovv.com/product-page/innovv-c5-lens-clip
@Nick Hillenius The screw size for fixing the bracket is M6.
If you want to use the K2 mount with the Gopro mount, the K2 and Gopro mount will not fit at the joint. Since the K2 holes are M6 but the gopro holes are usually 1/4, they cannot be tightened.
At present, we only have plastic C5 mount that are compatible with this gopro mount.
@innovv it's not the M6 on the side that i am talking about.
It's the thread on top.
With the new mountings they are all M6.
Sorry that I mislead you. i was one of the to buy the K2 and the mounts was one if the reasons why. Did not know the cheeped out on an important part like mounts.
@Peter Sandberg i dont blame anyone.
We both didnt knew that the mounting systeem has changed.
I hope they change it back or make one side with the 1/4 threading and the other M6 so people have more options on mounting the K2.
The rear mount. I google and it seem it can be bought.
@Peter Sandberg which rear mount?
Would u mind to share a web link?
Here is my setup, front and back.
I also added the arrow were it hangs on by one thread because i adjusted the threading from 1/4 to M6.
How did you adjust it from 1/4 to m6?
