I went for a ride last week and couldn't start my bike. Stuck on the side of the road for 6 hours. I replaced the battery and removed the Innovv K2 off the bike, at least for now. Has the issue with 40mAh draw been addressed? Drawing 40mAh when idle is very aggressive for a 7Ah battery.
I see post on this issue from other users but don't like the proposed band-aid of using a timer relay.
Is Innovv going to address the issue?
There is a new power converter which drastically reduces the power drain. You can contact Innovv for a replacement of the power converter.
Good to hear they had it fixed. Do you know how much it draws when idle?
@lightcatchr
According to what Rock said, it only draws 0,8 mA when idle.
I don't have the new converter, so I can't measure it myself.
First you can check the converter, New version has a LED light on.
If not, just send email to innovv@innovv.com, you will get support.
