I've been having intermittent issues with file corruption - they will not open at all. About 90% of the files are having this problem. I've read other posts regarding this - and as a result - checked all the cables. I had the BMW Motorrad dealer initially install the power, and all power connections still look super-solid. The DVR powers up 100% of the time, as well as both cams. I'm basically dead in the water here and could use some good advice on how to proceed. Thank you.
Hugh
Hi Hugh, Sorry for the problem you met, could you send us an email and we will help you.
cs@innovv.com
