Hello! Hoping for some help here. Just installed the K2 on my Street Glide. Everything works. Have GPS signal. Cameras working as they should. out of no where I can’t connect to the WiFi. I’ve tried my iPhone 8 (updated today), my ipad (also updated) , and my work iPhone 8.
All to no avail. I found a previous thread that had a manual configuration to connect. Tried that nothing. When I select connect to innovv WiFi my devices try three times and give up. All devices connect to both channels of my hone WiFi no problem and work WiFi no problem. please help!
thanks.
colin
Same thing happened to me. So after an hour of being frustrated I said screw this and let it go until the next morning. Everything was fine and haven’t had a problem in 2 weeks
@rcannata88 @rcannata88 I wish I had that result
Please go to iPhone > Settings > Privacy > Location Services to make sure that Location Services is on. If that still fails, please kindly try to forget the WiFi password and then reconnect again.
@Innovv locations services is on. I have tried the forget network on all devices. Hard power down the K2. Presses the rest button and retried with all three devices. Not sure what else to do.
Also try turning on Airplane Mode in settings, then turn it back on after a couple of seconds.
@Raymond Wand tried the airplane mode as well. No luck.
Apologize for any inconvenience that has caused. Could you kindly check the WiFi signal on the DVR when connect the DVR to any power also both of cameras being connected?
The blue WiFi indicator flashes while the DVR is on. My devices detect the DVR WiFi, but try to connect three times and revert back to my hone WiFi. not sure what you are asking with the cameras. They are connected and the retaining screws are tight.
Update. After being disconnected from power for 24 hours. Still will not connect. GPS light on solid. Green camera light flashing. will joy connect time wifi. All devices see the k2 WiFi signal. Just will not connect. I’ve reset the DVR. Unhooked camera cables , powered up, connceted the camera cables. Nothing. I’m going to attempt a firmware update with the memory card.
Update. Inserted memory card and formatted. Was able to connect right away with no issues. keeping my fingers crossed it’s good to go. Off to tail of the dragon and blue ridge parkway in the Smokey mountains.
Glad to hear that. Hope you would have more fun with INNOVV K2. May you have any other question, please feel free to contact us.
Hello, i have issues finding the wifi Innovv K2, it is not appearing on my iphone list
Could you kindly check whether the blue Wi-Fi indicator will flash or not when the DVR is on? Many thanks in advance.
No luck, I do everything and the camera do not came in my bluetooth, is time to return the camera and buy another one... so sorry look nice system
Hi Donald,
...and the camera do not came in my bluetooth,
ehhmm...you have to connect via wifi, not via bluetooth.
Hello Donald, apologize for any inconvenience that has caused first. Yes, the INNOVV K2 does not support bluetooth and it only supports Wi-Fi connection. You could kindly search INNOVV K2's Wi-Fi on your phone when the INNOVV K2 is connected to the motorcycle with ignition on. Then you could join INNOVV K2's wifi with the password. May you have any other question, please feel free to contact us.
