I have tried both my iPhone XR and my iPad Pro both running the latest iOS updates. I have remove and reinstalled the app on both devices. I have forgot the network on both devices. I can connect to the device to view videos. As soon as I try to go to the setting for the INNOVV the app crashes
When the App connectes to the K2, it first reads all settings of the K2. Maybe there is one (wrong) value within the K2, which makes the App crash. To check this, you can a) push the reset button on the side of the K2 or b) re-install the firmware. Both will reset all settings to default.
I reset the K2 and still no luck. I have a Samsung evo 256 GB card that I am using. The video On the DVR is sped up and the mph are way off. States I am going almost 2 times my speed. I have a trip on Thursday and hoping to get this working by then
Which model of your iPhone is?
Try to do below,
1. Settings=> WLAN => INNOVV K2 => Click "i" to get the information, and Click forgot.
2. Set your phone to airplane mode and enable WiFi only, then connect K2 WiFi again.
Keep updated after checking.
i have the same problem and still not working not sure what is the best way around this
Please download the last version of Firmware-bin file to SD card and insert SD card to DVR, and power on camera system.
Frostie is right.
I finally had time to install the latest bin file on the SD card. That fixed my problems. Thanks for the help
