Nice video quality and good sound when bike mounted mic, older k2 brought secondhand and all works fine but only realised why it cuts stops recording for a few seconds now and then, when i sound my horn the camera stops recording for a few seconds, good conn to battery and good conn to switched live, I have tried another horn, used a relay to power the horn seperateley from the battery, changed bike battery. I do bike electrics for a couple of bike shops so I know what im doing with wiring.
Does any one have any clues as to what might be problem. Bike is a 2016 tiger 800 xrt, it worked fine on my BMW K100rt
Glad it's resolved.
Have fun with your K2 now.
You may also want to connect the yellow wire to another switched power supply.
Did you place the dvr-unit near the horn?
A horn produces a large magnetic field when used and may therefore interfere with the dvr-unit.
Dear Sir
Sorry for the problem you got from the K2, would you please make sure the connection between the front lens and the DVR is tight enough? And please use a power bank or use wall charger to powre the K2 for about 2 hours see if there is any stops during the recording.
Thanks.
