I created a modified version of the new V47 firmware, where I set bitrate to 20k for 1080P and to 15k for 720p. It is completely untested and I am not planning to test it, because the V47 has no benefit for me.
But maybe you want to test if the modified firmware works as expected.
You can find the modified V47 in the same share as the V39.
Yes, I know. But I already tested 720p in V39 by directly modifying the resolution within the firmware. After that, I prefer 1080p :-) So I can live with the bug in the V39.
What I still would love to do is, reducing the sharpness a little bit. I know that the values are in the range of 0-100 within the firmware, but have not found the corresponding data field yet. Maybe you can tell me, what the current value for sharpness is. That would help me in finding the data field.
This firmware updated the last bug, that 720p 60fps was set but could not be saved after next startup.
That is all.
If you do not need to set to 720p 60fps, no necessary to update.
@Rock Liu
https://www.dropbox.com/sh/o3xnk8u4alospta/AAAX67-ELsL6KDDt92-F1SQTa?dl=0
Thank you for help, yes, we will do test.
At least, we now fixed the bug that 720p could not save.
@Rock Liu
Spam, just reported.
