Hallo
I installed the camera and it also films. Unfortunately, I cannot use the settings in the app. It flashes briefly and then turns off the app. Watch and download video works
The GPS doesn't work also
Hello,
Can you provide a detailed description?
Have you confirmed that converter is connected to a normal location? The yellow line needs to be connected to ACC.
Does the light on the DVR flash normally after you power it on?
Can you see WiFi from K2 on your phone?
Use a USB cable to connect the DVR and a power supply.
If it is not convenient to connect directly to a home power supply, you can use a power bank to connect, remember the output need to be 2A.
