Salve ho un problema dopo 1 annio con il mio innovv K2... Dopo che si accende la moto il dvr parte e dopo qualche minuto si spegne da solo... Non mi fa neanche collegare con WiFi al telefono... Cosa dipende a qualcuno è successo? Soluzioni?
If the power module goes out at higher temperatures, it will have to be replaced.
You can contact Innovv to order a new one.
Or you have to move the power module in such a way that it can be cooled better.
faro questa prova e vi faro sapere....che succede se si riscalda e si spegne? cosa dovrei fare?
Sounds like an (internal) temperatur issue in the power module.
I can remember that one of the early series of the power module had issues at higher temperatures.
If the K2 is now back running, are you able to heat up the power module during operations just to check if it will fail? For example by using a hairdryer or a heat pistol?
il filo giallo e' alimentato e si e' spento lo stesso....in quei pochi minuti non e' stata rilevata alcuna registrazione... prima non vedeva il wifi ...ora dopo 6 ore a riposo funziona di nuovo...per il modulo di alimentazione non ricordo se con led o senza
Hi Francesco,
Does the DVR turn off completely after a few minutes? Or is it just the wifi that goes out?
And if the DVR goes all the way off after a few minutes, is there still power on the yellow wire? And what is the voltage on the red wire?
In those few minutes that the DVR was on, was a recording made? You can check this by looking at the SD card in the computer.
Is your phone not seeing K2 WiFi at all?
Do you have a power module with or without LED? If you have one with LED, does it glow blue? Even if the DVR turns off after a few minutes?
It's just a few questions, but the more we can get clear. The greater the chance that we can help you.
