In this thread I will explain how to do modifications to the firmware of your K2.
I will try to keep it as simple as possible, but you will still need at least a minimum of computer experience to be successfull.
But before I start...
Disclaimer:
I am not responsible for any damage you do to your device. Although I am quite confident that it is nearly impossible to damage the K2 by modifying the firmware, I cannot guarantee it.
So everything you do, you do at your own risk. And please remember, that installing a modified firmware can void your warranty.
This thread is separated into four sections.
Basics Here I will lists the necessary tools and explain some things you should know to understand what I am talking about.
How to make the firmware editable / Uncompressing the firmware Here I will explain the necessary steps to uncompress the firmware, so we can edit it.
How to make the (modified) firmware installable / Compressing the firmware Here I will explain the necessary steps to re-compress the modified firmware, so we can install it to the K2.
How to do modifications Here I will explain how to do each modification. What settings can be changed, how you can find them in the firmware and what values are valid.
1.Basics
To modify the firmware of the K2, you will need some tools.
NtkTool (for compressing/uncompressing) the firmware file. You can get it here. This tool requires Java to run. There are also two command line tools for packing/unpacking and Checksum calculation on this page (Windows/Linux), but in this guide I will only refer to the GUI based tool, because I think most of you will prefer this tool. Just because it is easier to use.
A Hex Editor There are several free Hex Editors for Windows, MacOS or Linux in the net. For example: Windows => https://mh-nexus.de/en/hxd/ MacOS => https://sourceforge.net/projects/hexedit/ Linux => https://sourceforge.net/projects/wxhexeditor/ (should also be available in the repository of your Linux distribution)
A Calculator which is able to convert hex > decimal and vice versa. You can switch the Windows Calculator into a different mode, where it can do this. Don't know if the Apple Calculator can do the same.
Now some basic stuff you should know to understand what I am talking about and what you will see when editing the firmware.
Byte
This is a unit of digital information. Without going into details, when using a hex editor you should know that a byte is always represented by two digits.
Hexadecimal
When using a hex editor, the bytes are shown as hexadecimal values. Like 4a, fe, 0c and so on. See also https://en.wikipedia.org/wiki/Hexadecimal
So if you, for example, want to change the volume from 8 to 12, you would have to enter 0c, as this is the hexadecimal representation of the 12.
Offset
An offset indicates the distance of an address, originating from another address. In our case, from the beginning of the file. Your Hex Editor will show you the offset.
DWord
This simply means four bytes. Any instruction is four bytes long and so are most of the data fields. Even if the value is small enough to fit into one byte, the firmware still uses four bytes.
Little Endian Encoding
The firmware uses something that is called little endian encoding. This means, that the least significant value is stored first. Or in other word, bytes are written in reverse order.
This is important to know when changing values within the firmware. So here are some examples.
10 decimal = 0a hex. Expanded to four bytes, this would be 00 00 00 0a. As the least significant bytes has to be written first, this changes to 0a 00 00 00
1920 decimal = 07 80 hex. Expanded to four bytes, this would be 00 00 07 80. The firmware will store it as 80 07 00 00
240570 decimal = 03 ab ba hex. Expanded to four bytes, this would be 00 03 ab ba. The firmware will store it as ba ab 03 00
2. Uncompressing the firmware / How to make the firmware editable.
The firmware file is compressed, like a zip file. So before doing any modifications, we have to uncompress it. But before doing this, we first have to check
what type of firmware file we've got. For reasons I don't know, the firmware file sometimes consists of two partitions and sometimes only of one partition.
This is important to check, because the tool we will use to compress/uncompress the firmware will can not handle multi-partition files.
Luckily, the types are easy to distiguish by its size.
Filesize = 2,8 MB => One Partition
Filesize = 4 MB => Two Partitions
If the firmware file only contains one partition, step over to "Uncompressing the firmware".
If the firmware consists of two partitions, we have to do some more steps to cut off the second partition to append it back later.
So head on.
Two-Partition Firmware only
Open the firmware file in your hex editor
Search for the string "BCL1". You should find it two times. Right at the beginning at Offset 0 and somewhere around Offset 2B3110. The later one is what you are searching for. Here is the second partition we want to cut off.
Mark the first byte which makes the "B". Now move up 40 bytes and you are right at the beginng of the second partition. Cut off all above this point and save the remaining file as "part-1.bin". For better explanation, here is a screenshot of the V57 firmware
We have now saved the second partition and can go on uncompressing the firmware.
Start the ntkTool
Click the "Load firmware" on the left and select your firmware file.
Now click "Unpack" to uncompress the firmware. If you firmware consists of two partitions, you will see them both here. Ignore the lower one (partition-1) und simply unpack the upper one (partition-0).
The tool will save the umcompressed firmware as <original filename>@00000000.rbn. Like K2@00000000.rbn
That's the file we are going to modify.
3.Compressing the firmware / How to make the (modified) firmware installable
Start the ntkTool
Click "Open" at the "Pack firmware" option on the right side and select the modified firmware.
After that, simply click the "Run" button below.
The Tool will calculate the checksums and compress the file, which takes some seconds. The compressed firmware will be saved with a .bcl extension. So if your uncompressed firmware is "K2@00000000.rbn", you will get a "K2@00000000.bcl".
If your firmware is a One-Partition firmware, you are done now. Simply rename the .bcl file to "K2.bin" and flash it to your K2.
If your firmware is a Two-Partition firmware, you have to do some more steps. So read on.
Two-Partition firmware only
We now have to concatenate the newly compressed firmware file and the second partition, we saved before uncompressing the firmware.
The easiest way to do this is by command shell.
So open up command.com (Windows) or Terminal (MacOS/Linux) in the folder where your firmware files are.
Then type the following command.
Windows:
copy /b <your modified compressed firmware> + part-1.bin <name-of-the-finished-firmware> For example
Linux/MacOS:
cat <your modified compressed firmware> part-1.bin > <name-of-the-finished-firmware>
For example
That was easy. Now to the tricky part. As the part of the firmware we modified now may have a slightly different size, we need to check the offset of the second partition and adjust it, if necessary.
Open the K2-modified.bin in your Hex Editor
Search for the string "BCL1". You should find it two times. Right at the beginning at Offset 0 and somewhere around Offset 2B3110. The later one is what we are searching for.
Mark the "B" and write down its exact offset. In the screenshot, it is 2B 31 10. (click to enlarge the screenshot)
Now move up 12 bytes. There you will find the old offset, but in reverse order. In the screenshot, this is 11 31 2B 00. Reading backwards, this is (00) 2B 31 11
If the old and new offset do not match (which they don't here), you have to adjust it. So in this example, we would have to change the "11 31 2B 00" to "10 31 2B 00".
Save the file and we are done. We can now rename the file to K2.bin and flash it to the K2.
4. How to do the modifications
In this section I will list all settings which I have discovered so far. For each one, I will provide..
- the original default value (as it is saved in the firmware)
- the offset where to find the setting in the V0.70 firmware.
- a search pattern for the setting
- the allowed value range
Why a search pattern? Because the offset for a setting differs from firmware to firmware. In V0.57 the sampling rate is at 4f68c0, but in V0.70 it is at 4f7a98.
So you would need some kind of pattern to search for it in future firmware releases.
Some words about the settings, which can also be changed via the App (e.g the Wifi Timer)
Changing them by modifying the firmware will only change the default value of this setting.
You can still change them via the App and the K2 will still save them.
Remember that any value is in hex and little endian encoded (see Basics).
Audio Volume
Default value : 08000000 (=8)
Offset : 0da300
search pattern : 08000000 14000000 03000000 58440000
Allowed value range : 0 - ff (decimal 0 - 255)
Audio Sampling Rate
Default value : 007d0000 (=32000)
Offset : 4f7a98
search pattern : 00000000 01000000 007D0000 02000000
Allowed value range : Did not check all values. 48000 kHz works. (80BB0000)
Video Brightness
Default value : 06000424 (=6)
Offset : 1d4b08
Search pattern : 06000424 F80044AC 05000424
Allowed value range : 00000424 - 0c000424 (00 (lighter) => 0c (darker))
Comment : This is an Assembler instruction. You are only allowed to change the first byte (default 06). Otherwise the firmware may not work.
Video Contrast
Default value : 32000324 (=50)
Offset : 1d54d0
Search pattern : 32000324 A80103AE (pattern may not work on all firmwares)
Allowed value range : 00000324 - 64000324 (00 (lighter) => 0c (darker))
Comment : This is an Assembler instruction. You are only allowed to change the first byte (default 32). Otherwise the firmware may not work.
Wifi Mode
Default value : 2c0340ac
Offset : 1d4b1c
Search pattern : 2C0340AC 400140AC 380140AC
Allowed value range : 2c0340ac = AP Mode (default), 2c0343ac = STA Mode
Comment : This is an Assembler instruction. You are only allowed use the two options for AP or STA Mode. Otherwise the firmware may not work.
Wifi SSID
Default value : 494E4E4F 56565F4B 325F0000 (String "INNOVV_K2_")
Offset : 4f6e38
Search pattern : Search for String "INNOVV_K2_". The first occurrence is the string you are looking for.
Allowed value range : Anything you want, except special characters like $,% or german umlaut. Max length is 32 characters.
Comment : In AP Mode, the K2 will automatically add the last four digits of the serial number to the SSID. In STA Mode, the SSID will be what you enter here.
Wifi Password
Default value : 31323334 35363738 (String "12345678")
Offset : 4f6e78
Search pattern : 31323334 35363738 00000000 00000000 00000000 00000000 00000000 31323334 35363738 This will find two passwords. The first one is the correct one.
Allowed value range : Anything you want, except special characters like $,% or german umlaut. Max length is 26 characters.
Wifi Timer
Default value : 02000324 (= 2 => Wifi Timer off)
Offset : 1d54e0
Search pattern : 02000324 8C0303AE 080202AE
Allowed value range : 00000324 - 02000324
Comment : This is an Assembler instruction. You are only allowed to change the first byte (default 02). Otherwise the firmware may not work.
Motion Detection
Default value : 700100ae (= 0 => Motion Detection off)
Offset : 1d5488
Search pattern : 700100AE 580100AE
Allowed value range : 700100ae = Motion Detection off (default), 700102ae = on
Comment : This is an Assembler instruction. You are only allowed to the two options for on or off. Otherwise the firmware may not work.
more to come
Gosh, you've done a good job.
I am excited to get started with this myself.
Maybe if the weather here is too bad to ride a motorbike, I can also learn more about it.
Thanks.
Finding this part in the firmware, which sets all the default values, nearly took me three weeks (some hours every evening). Mainly because I first had to learn a little bit about MIPS Assembler to be able to follow the instructions and branches.
Added Motion Detection and Video Contrast to the list of settings.
Instead of searching all addresses for those settings, which can be changed by the app, I will now focus on finding those values, which can't be set. Like saturation, sharpness, etc.
Unless someone needs to know the address for a specific setting.
