Hi guy's I seem to be getting a lot of locked files (video recordings) on my device when I press delete it says "fail file is locked" and the video remains!!
Why are so many incident free videos locked and how do I delete them??
Yes we know why the files get into the 'park' directory. I was just suggesting away of avoiding getting too many 'saved' files as looking through loads of files to see if they are relevant can be very tedious and also take up valuable of mem space.
I have the same problem but with all the files, my memory is full. I try to change the ¨G¨sensor but my app going crash when I try to go to setting, so I can´t do nothing. I will going to upgrade and format the SD to try to solve this. Do you have other solution to try different?
Cant help you with the APP crash Ricardo, but I mounted my DVR on two small foam rubber pads. With the 'G' sensor set to low I only get a few files dropped into the 'park' (locked) directory. Dont cover the whole bottom of the DVR in foam as this might prevent heat dissipation.
Every time the G-Sensor detects a shock greater than its threshold, the video gets moved to the park folder, which is write-protected. There is no way to delete those files using the App or the Web-Interface. This can only be done by USB or by removing the SD Card and put it into your PC.
@paulouk I just find the way to solve the crash problem with the app. So I change the G-sensor configuration for lower. I will going to check how its work with this new configuration. thanks.
You may be getting a lot of locked files in the 'Park' directory because of bumps and vibration. Try turning the 'G' sensor to a lower setting.
Copy the files you want to keep then format the card
