Hi, just had the K2 installed, and the initial recording came out fine front and rear. I've adjusted a few of the settings, but can't find anywhere to adjust the time stamp - the date is correct out of the box, but the time is way off. How can I adjust that?
Also, I have opted for speed to be shown in mph, but on the video it's shown as kmph!!
Thans for any help with these two small issues.
I thought the time was set by the GPS
I've since been told by the customer support team that it's set by the phone that connects through the app upon initial installation (and I guess there's an internal battery in the DVR that keeps it going). But, as the time on my phone is correct they're looking into why it's not synched properly.
I'm having the same problem. Mine is off by one hour. I originally set up the unit during daylight savings time but now with the time change it's off an hour (still on DST). How do I update? -JEP-
When the time changed recently I managed to make the change on the cameras by simply going into the settings option on the app, and then out again. It seems that the time on your phone will only be synched to the K2 if you "link"them both together through the K2's wifi. At least this seemed to work for me. Good luck.
That worked! It just needed the correct time from the outside world. Thanks. -JEP-
Time, we all know is the most precious entity and we have to manage all the things. Mostly you have to take care about resume writers that can give the optional ideas that will be more enhancing and flourishing.
