Struggling to do the update on firmware.
right I have gone through this about 20 times but it will not update.
i have formatted the micro sd via the app when installed in the unit,
removed the sd plugged in to my pc opened up, can see just innovv folder added downloaded file beside folder K2.bin,
press safe to remove it
plug back into unit no red camera flashing, log on to innovv say still need to update.
what am I doing wrong ??
spent about 2 hour trying to update it.
It worked thanks for your help EZ 👍🏻
Was just reading about the K2bin file disappears once I have inserted it to the unit which it does so think your right cheers 🍻
Hi Ethan, thanks will try and find a smaller sd card then, thanks for your help 🏍👍🏻
OK, I had the same issue last night trying to do the same to latest version 61. Are you using sd card 128/256GB? The solution was to download the bin file to SD card that is 32GB or less and then it was successful. Give it a try.
Good luck.
