I just got a new K2 dual camera system straight out of the box. I did a bit of a test before fitting it to my bike. Recording seems to work OK, app connects and shows video, but the GPS light on the DVR keeps blinking at approx. 2 seconds interval. Does that mean there's no GPS fix?
I kept the receiver outside, well in view of the sky, for over 2 hours, still blinking. Please advise.
I seem to have the same problem still working on it had it for a week now, will update you if I can sort it
did you ever fix it
Hi,
My experience with testing is that you need a good powersupply to test.
The GPS antenna does not work if the power supply is too low. At least that is my experience.
I did some testing with different power banks with different power. That is how I came to this conclusion.
Just as an idea.
Did you all checked that the gps plug is plugged in really to its end? Some plugs are misshaped and won't fit correctly.
I had this issue. After going through all the checks (connection, unit position,moving bike to a different location etc) I contacted support, went them some video of the setup and the DVR gps light flashing and they replaced the GPS unit. Works perfectly now.
N.
Thanks for your replies. Finally got around installing it all, still looks like no fix but will do a bit of touring first to see if it's really not working. Will keep you posted!
Mines intermittent, sometimes it works sometimes it doesn't.
Got the same problem. Yesterday full gps data recorded. Today NOTHING
I tried 2 units, both fail with GPS. No support.
as mentioned, can you please forward emails you sent for support to rock@innovv.com, I'd like to learn into details.
It has been a while with holidays and all that. Eventually the seller of my K2, send me a new GPS unit and that actually fixed my problem. Light stopped blinking and Dashcam Viewer can now extract the GPS data from the video streams.
