When I use the Dashcam Viewer to display the films on the memory card I also see the data of the GPS location and the speed, but if I copy the files to my computer and try to view them in the same app. Unable to see location and speed data.
Is there a way to copy all the data together ?
The GPS data are encoded within the video. Means...if you copy the video file, you also copy the GPS data. There must be a another reason why your Dashcamviewer can see the GPS data in the videos on the SD Card, but not after copying them to your pc.
After I copy the files from the Sd card to the pc all the gps points become 00000 somwhere in the ochian .
also the speed is 0 (I can see it when I try to export as Gpx fileonly if I export from the file I copyrd to th pc)
Did you try to copy the files and play it from the hard drive on your pc ?
The problem is resolved. The directory name and file name must be in English otherwise the Dashcam Viewer does not know how to extract the data from the file.
@shumi
I thought so and this would have been my next question.
Many programs have difficulties with special characters. Not only small utilities, but also professional and expensive programs. Just got a certificate lifecycle management solution at work, which completely freaks out at german umlaut characters :-)
And back to K2...never use german umlaut in the wifi name. You will not be able to remove them, only by re-flashing the firmware.:-)
