Hi,
I have install and remove everything twice and I found out that the front camera becomes very warm. Then it freeze and the whole system at reboot/restart of the bike is not working (it seems that the whole system is constantly rebooting and wifi is not available)...
Did someone had this kind of trouble?
Thanks
I did all the test possible. When only the rear camera is plugged to the front, it works fine and when I add the front one it bug again... i asked the seller to replace it.
Hi, check again to see if the connection is strong or switch lenses.
Hi
the front cam should not get noticeably warm.
That the system is constantly rebooting will be an aftereffect of the failed front cam. The DVR needs the front cam to start. Without it, it constantly reboots trying to find the missing cam.
Please switch the cams on the DVR (front to rear port and vice versa) and check what happens then. If the error follows and the front cam (which is now connected to the rear port) still fails, I would guess this cam is faulty.
If the error does not follow and now the rear cam (connected to the front port) fails, there is something wrong on your DVR. Maybe the port itself.
