Hello,
I need your help.
I can't figure out how to get the video from the front and rear cameras at the same time.
However when I watch live while stationary I have no problem, I can see both.
But as long as there is a recording, I end up with all the files separated?
I did several tests with the app on my phone, but to no avail.
Otherwise, it's really not bad;)
Thank you for your help.
Wink From France
In the live view, you can see both cams at the same time. But this is only for testing/adjusting. When recording, the videos of both cams are saved separately.
That is the normal behaviour. There is no "picture in picture" recording.
You would need to use a video editor to get the effect you want. Like kdenlive.
Thank you for your kind reply here. 😀
With the program dashcam viewer you can view the front and rear recordings at the same time.
You can also view the recorded GPS data with this program.
Thank you very much Frostie for your response, I will download this software to view it.
Hans, thanks also for this comment, however, you are saying that with dashcam viewer you can see front and rear recordings at the same time.
If so, how do you do it from the app?
In the Innovv app it is only possible as described by Frostie. You click on the film camera symbol in the app to view the video images.
In dashcam viewer, software for computer, no app (https://dashcamviewer.com), you can view both recorded recordings (front and rear) at the same time.
It is not possible to view both recordings at the same time in the Innovv app. Below a print screen of Dashcam Viewer.
Hans,
Ok I understand, thank you very much for this additional information!
