I've just done this. Front camera is fixed under the middle of the front fairing, using one of the centre screws holding in the headlamp units and some heavy-duty velcro. Th rear camera is mounted to one side beneath the Givi rack. I'll give you more detail later - out to dinner now!
Here you go. The OE K2 bracket hangs beneath one of the four bolts that fix the two halves of the SR357 rack together. No drilling required. It's not ideal, as the camera is by no means hidden, but it's the best I could figure out. Without the rack I've no idea how you'd tackle the expanse of plastic that is the rear of an FJR!
Thanks for sharing. I don't have a Givi mount but that looks like a decent location. I found someone who bored a hole through the plastic but not sure how it is secured on the inside and it looks like the field of view may be cutoff by the license plate light.
Hey thanks for the info. I think the front looks pretty straight forward could you send a pic of how you did the rear? Thanks again
