Hello all
I have just installed my K2 and the app says I need to install the latest Firmwar. Current version K2.20190614.Vo.57
i have downloaded what I think is the latest version from the INNOVV website K2.20190824.V0.61 to the SD card but it doesn’t update the system.
Can anyone tell me where I am going wrong?
Thanks in advance
Steve
Please take a look at my posting here
https://www.innovv.com/forum/innovv-k2/firmware-update-fails-if-using-new-exfat-format-in-v-52-firmware?commentId=5d948672062e15001781783d&origin=notification&postId=5d8639f69ccc31002d34207c
In short:
Re-format your SD Card on your PC in FAT32
or
use a SD Cards not bigger than 32GB, which has been formatted in the K2.
Or, you can test what Innovv posted here
https://www.innovv.com/forum/innovv-k2/ios-13-1?commentId=5d948672062e15001781783d&origin=notification&postId=5d8639f69ccc31002d34207c
Many thanks for the quick reply.
I will try this tomorrow
Frostie, thanks for the info. Tried it with a 16gb card and it worked like a champ.
Hello, new to the site and innovv K2 system. bought a used bike and it has front rear / left right camers ... installed the app on my phone ... i can connect to DVR but it reminds me to install latest firmware ...
can somebody help me locate the K2 firmware download? i can not seem to find it on this site anywhere .... Thanks
Try the below:
https://www.innovv.com/innovv-k2-support
There is something wrong on the Innovv Page. The link to their dropbox isn't there anymore.
But you can use my dropbox, as I saved all firmware files just in case :-)
@Frostie @davidrarden
We have corrected the website and now the download location of the firmware has been changed.
Follow this path to find the firmware download and other files you need.
Ahhh.. it has moved from "K2 Support" to "K2 FAQ" That the last spot where I would seach for firmware updates :-)
According to the feedback from the guests in recent days, we still added the download on the K2 SUPPORT page.
The FAQ page will also be kept.
I want to download the latest firmware.
Dropbox link is not working properly. Clicking on the link does not work. I now need to copy the link to my browser.
I also need to create a Dropbox account first.
Previously, you could immediately download the firmware without logging into Drop-box. This was a bit easier.
We will check again this firmware link.
Yes. The same already happend some month ago. They copied the link to the firmware folder itself while being logged in to their account instead of the link to the share.
Therefore accessing the link requires to be logged in.
If I log in to my account first and click on the link, I get the message..
("The Folder /wix website/...../ does not exist"). Which is correct, as this folder does not exists in my account.
Innovv has to fix this. In the meantime you can download the original firmware from my dropbox.
@innovv
While being logged in to your Dropbox acctount, click "Shared" on the left side.
Then select "Links" in the main windows to show all shared links. Select the link of the firmware files and click on the right icon (...). There select "Link Settings".
Then you will be able to copy the correct share link. This needs to be put on the web page.
Thank you very much for your guidance, and we will put the download link for firmware in the right place as soon as possible.
Update - The icons of K2 support and K2 FAQ page have been modified.
Now click the icon to download the latest firmware directly. @Hans
Which version is it and what has changed?
https://www.innovv.com/forum/innovv-k2/innovv-k2-firmware-version-details
Here you can see the differences between versions and fixes made.
